Fuel tank thingy
Re: Fuel tank thingy
Edit on plug material
It’s a higher content carbon steel , it looks like it’s plated itself with brass so appears like brass and when you drill it it flakes not ribbons .
I would suggest HSS drill bit rather than high carbon as it might work harden and the only way is carbide then .
Mine had the same plug in and although I got a nos drain pipe I didn't put it in for ease of use but have it handy if I ever decide to.
- gs.davies
- Has thanked: 75 times
- Been thanked: 78 times
I need something to seal this hole off in my tank. Will a 3/8 grub screw do the job? If so, what should I seal it in with?
- timmy201
- Been thanked: 42 times
How about a bleed nipple off a disc caliper? It’s 3/8 unf and hopefully the right taper
http://www.minispares.com/product/Class ... H2428.aspx
A bleed nipple works fine. I put one in one of my tanks years ago & never had any issues.
- Has thanked: 150 times
- Been thanked: 137 times
If it's the brass bung type as shown by Beattie (previous page, then just clean and fill thread with soft solder. End of problem
- Been thanked: 20 times
Quite a long time I seem to remember from earlier in the year when I got shot of the dead petrol - had to blow through with the air line to clear it first. A bugger to loosen as well, I extended an old box spanner with a bit of tube and that worked.
I fitted a NOS original to HOY obtained from a fellow forumer from Australia, if I remember correctly.
It is basically a 3/8 UNF bleed nipple with a piece of tube brazed on to it.
Copper-slipped it and made a suitable long box socket to allow tighten up and potentially loosening it.
That’s a genuine plug , can’t remember the part number, got a bag of them somewhere.
21A352!SMOKE GREY wrote: ↑Thu Jan 12, 2023 8:49 pmThat’s a genuine plug , can’t remember the part number, got a bag of them somewhere.
- winabbey
- Has thanked: 7 times
- Been thanked: 15 times
To summarise some of this discussion, the initial drain plug part 21A352 (as per Beatie's post) was replaced by the plug with tube - part 21A1401.
This image courtesy of Somerford Mini - https://www.somerfordmini.co.uk/catalog ... 774_100807
BMC Australia made its own equivalent of 21A1401 giving it part number AYA2150 for the threaded bit and AYA2149 for the assembly.
- gs.davies
If ever there was an advert for the usefulness and the depth of knowledge available here, just see the post above.
Brilliant!
Brilliant!
- Has thanked: 20 times
- Been thanked: 52 times
Really useful info, and just found this in the site's BMC bulletin - with dates
- gs.davies
Right, finally got to the stage where I can fit the tank and the boot floor has the hole in the wrong place. Ho hum (M-Machine Mk1 Spec floor). What glue would folks recommend for this task? I've tried a calliper plug screw, that's too short to go all the way up to the taper and I suppose the nipple should be tight against that to seal it against leaks.
JB Weld followed by a 3/8 UNF grub screw. I have ones that have been like that for 30+ years & have never had any issues.
winabbey wrote: ↑Fri Jan 13, 2023 5:30 am To summarise some of this discussion, the initial drain plug part 21A352 (as per Beatie's post) was replaced by the plug with tube - part 21A1401.
I’m not sure that’s quite correct. The drain tube with pipe is pictured in the original Mini Cooper parts list and is labelled as 21A352
Confusing!
- Has thanked: 42 times
I'm just getting to this issue at the moment, as mentioned by Andrew - it's there and would like to return same even though I can see they are a right pita. Dermott directed me to some for sale in Australia but their web site doesn't seem to be set up for selling abroad - pinged them an email but no response.
I'd like to know if the grommet is just a blank with a hole through or whether it is a thicker moulding that also acts as a supression rubber?
The slinger thingy however is still a hurtful point Andrew - my therapist has given up trying to get me through this
- timmy201
There’s a few places in Aus that sell them. If you want to order a few to make it worth the shipping and fees I’d be happy to receive them and post them on
https://bmiparts.com.au/product/drain-tube-fuel-tank
https://minisport.com.au/products/mini- ... be-spanner
- winabbey
I sent a small quantity of the NOS tubes to someone on here, but can't remember who.
