64 Austin Cooper S 1071.
skorstensfejeren
Re: 64 Austin Cooper S 1071.
Post by skorstensfejeren »
New letters printed on the front plate
skorstensfejeren
The Heater is ready to put back in the car.. ( When the car is ready too :roll: )
skorstensfejeren
Jobs done... :)
NotNormal
Post by NotNormal »
Great work, in regards to the heater how did you go about re-doing the white letters?
Reason I ask is I have this job to do myself at some point?
STG95F
Post by STG95F »
And me , also what make paint did you use for the front ??
Ian
skorstensfejeren
Hi...
The paint is VHT wrinkle plus... quite great to work with.. :). Just need to practice a few times to do it right, and get the correct crackle.. more paint = more crackles....
The letters is screen printed on by a company here in Denmark.. you can´t do that by your self good enought I belive. But I´ve been in contact with a man i Uk too. He´s name is David.. You can try to contact him on:
http://www.adgscreenprinters.co.uk/ He might be able to help you with the letters.
Regards René
skorstensfejeren
Some new photos from my rebuild project. From March. 2011
Last edited by skorstensfejeren on Wed Jun 08, 2011 4:30 pm, edited 1 time in total.
skorstensfejeren
Last edited by skorstensfejeren on Wed Jun 08, 2011 4:36 pm, edited 2 times in total.
skorstensfejeren
skorstensfejeren
The SU AUF 201 fuel pump is now tested and done.. so a part more to lay on the shelf
sclemow
Post by sclemow »
Sorry to interrupt, but regarding the heater lettering - I used letraset rub down transfers. These are easily available and cheap.
JC T ONE
Post by JC T ONE »
Looking good 8-)
36inter
Post by 36inter »
Thats a great restoration, the detail shows the passion you all seem to have for getting things right, first class.
sclemow, do you have a size and script type that you have used for your heater, that would be good information.
skorstensfejeren
Hi 36inter..
Thanks for your kind words. Always nice that someone like what they see, after many hours of work...
The correct script type is HELVETICA. I can´t remember the size, but will find it for you.
Regards René
sclemow
Post by sclemow »
I'll see if I can find the letter set.
camshaft2
Post by camshaft2 »
Heater front plate lettering is Letraset Helvetica Medium Condensed 3mm, RDC0130.
I used the VHT crackle paint from Frost and then rubbed the letters on using the tool provided with the Letraset.
Paul
skorstensfejeren
Working on the front brake calibers.
skorstensfejeren
The 1071 is now in the subframe. The brakes, pipes, drive shafts and so is done, so ready to go in the car when it´s ready. ( or putting the body shell on more correctly )
steve1071
Has thanked: 10 times
Been thanked: 13 times
Post by steve1071 »
Wow, fantastic work. I wish mine was that far along.
scott6058
Post by scott6058 »
steve1071 wrote:Wow, fantastic work. I wish mine was that far along.
Me too :o
