RE: the body number on that, I think it's been painted over quite heavily, so probably only just shows when it catches the light. As it does in the first picture, in the second picture I think you can just make out a few dimples in the paint that would probably be the body number...surfblue63 wrote: ↑Sun Oct 17, 2021 5:19 pm Someone left a deposit on that, are they mad?
Also a bit of doctoring on the pictures
Body number here
Body number gone?
1275 GT thread
- Has thanked: 4 times
- Been thanked: 9 times
Re: 1275 GT thread
Re: 1275 GT thread
They look like the marks of a bit of photoshopping to me.InnoCooperExport wrote: ↑Thu Oct 21, 2021 12:07 pm in the second picture I think you can just make out a few dimples in the paint that would probably be the body number...
Re: 1275 GT thread
Yes the seats look completely wrong - I've seen fatter pancakes... I agree that is Inca Yellow - not Bronze. Under bonnet shots carefully taken - I wonder if there are holes and big grommets in the inner wings, if its a single or twin bolt subframe, if it has a body number on the slam panel, which side the bonnet prop is on etc....surfblue63 wrote: ↑Thu Oct 21, 2021 10:57 am I wonder if it started life as an Inca Yellow Clubman. Those Newtons seats look lifeless and flat.
- Has thanked: 12 times
Re: 1275 GT thread
Was Inca yellow available on a GT in 69/70 i thought that was later colour66Traveller wrote: ↑Thu Oct 21, 2021 2:45 pmYes the seats look completely wrong - I've seen fatter pancakes... I agree that is Inca Yellow - not Bronze. Under bonnet shots carefully taken - I wonder if there are holes and big grommets in the inner wings, if its a single or twin bolt subframe, if it has a body number on the slam panel, which side the bonnet prop is on etc....surfblue63 wrote: ↑Thu Oct 21, 2021 10:57 am I wonder if it started life as an Inca Yellow Clubman. Those Newtons seats look lifeless and flat.
Re: 1275 GT thread
Unless I'm mistaken I think I can just about make out the rough shape of a big single subframe bolt partiality obscured from vision by the radiator overflow pipe
- 111Robin
- Been thanked: 17 times
Re: 1275 GT thread
"We acquired this mini in 2016 from the Isle of Man and it had previously been restored with some non standard parts."
Namely shell, subframes, engine, otherwise genuine.
- winabbey
- Has thanked: 5 times
- Been thanked: 14 times
Re: 1275 GT thread
There's a car for sale here in Australia for AUD $25,000 (GBP 13,500) or offer that claims to be a 1275 GT.
Does it look to be the real deal?
Re: 1275 GT thread
https://www.ebay.co.uk/itm/124950973282 ... SwHDphZqM5
At least this one isn't pretending to be a 1970 - however that isn't 'deckchair striped upholstery'....!
- Has thanked: 144 times
- Been thanked: 125 times
Re: 1275 GT thread
The number stampngs lood decidedly wring to me Winabbey. The clutch lever has been bent to suit. There's probably a few other faults too
- mab01uk
- Has thanked: 246 times
- Been thanked: 221 times
Re: 1275 GT thread
But part of ad does say: "only the seats being trimmed in a more modern material but retaining the original colours and the original seat covers still with the car should you wish to refit them."66Traveller wrote: ↑Fri Oct 22, 2021 6:55 am https://www.ebay.co.uk/itm/124950973282 ... SwHDphZqM5
Re: 1275 GT thread
Those seats are, well not to my taste. I would be concerned about the crinkles on the drivers side inner wing near the grommet and bend, looks to be some odd hammer marks there. And what is it about the makers of the stripes, those are just completely wrong.66Traveller wrote: ↑Fri Oct 22, 2021 6:55 am https://www.ebay.co.uk/itm/124950973282 ... SwHDphZqM5
Re: 1275 GT thread
It may have had a half inner wing repair panel.
As for the seats being the original pattern in a modern material ...
They are miles off (and really let the car down) - these are much more accurate.
https://www.aurum92.co.uk/product/late- ... -material/
- Costafortune
- Has thanked: 32 times
- Been thanked: 38 times
Re: 1275 GT thread
It's also got an A+ engine with a 'vertigo' clutch!66Traveller wrote: ↑Fri Oct 22, 2021 6:55 am https://www.ebay.co.uk/itm/124950973282 ... SwHDphZqM5
- Been thanked: 13 times
Re: 1275 GT thread
I wonder how good the cooling system works with the fan fitted back to front? Blades look pretty curly too so a new fan would be in order.66Traveller wrote: ↑Fri Oct 22, 2021 6:55 am https://www.ebay.co.uk/itm/124950973282 ... SwHDphZqM5
Re: 1275 GT thread
Just had another look at the engine bay and it appears that the whole engine has been sprayed with that car dealer varnish that peals off and looks horrid after a couple of months. Either that or it's been sprayed all over with WD40.
- Ronnie
- Been thanked: 31 times
Re: 1275 GT thread
I bet that would make your head spinCostafortune wrote: ↑Fri Oct 22, 2021 8:31 pmIt's also got an A+ engine with a 'vertigo' clutch!66Traveller wrote: ↑Fri Oct 22, 2021 6:55 am https://www.ebay.co.uk/itm/124950973282 ... SwHDphZqM5
At least this one isn't pretending to be a 1970 - however that isn't 'deckchair striped upholstery'....!![]()
- Exminiman
- Has thanked: 54 times
- Been thanked: 52 times
Re: 1275 GT thread
