Time lapse full metal Broadspeed GT restoration/transformation
Dr.Mabo
Been thanked: 37 times
Re: Time lapse full metal Broadspeed GT restoration/transformation
Post by Dr.Mabo »
timmy201 wrote: Sat Oct 17, 2020 10:41 pm Should be pretty quick now that the hard bit is done :D
Oh, I wouldn't say so. Even when the external modification and panel shaping seem to be done, there is a lot of internal work following to stiffen the bodyshell.
harrymini wrote: Sun Oct 18, 2020 8:38 am Looks amazing, what colour will it be going?
The colour will be excactely as on the first post, Surf Blue with a white go faster strip 8-)
so long
the Doc
My previous project:
Fanfaniracing
Has thanked: 6 times
Been thanked: 18 times
Post by Fanfaniracing »
That will be a super colour combination!!!
Dr.Mabo
Post by Dr.Mabo »
From the external view the conversion seems to be done and the hard work is over. But in reality the internal modifications and the detail work is sometimes even more challenging. To make the new modified body stiff and strong causes a lot of head scratching.
First the aperture of the rear screen. To cut out the correct aperture was easy. But usually screen and seal are sitting in a recess, except on 59’ Minis ;) . To form the recess like that, it’s the job of a beadroller. But therefore the panel is separated from the body shell. And as I had to weld several panels together to form the rear screen aperture, there was no way to use the beadroller before welding.
Thus I had to form the recess after the cut out was made. To make matters even more worse, the bead sits very prominent in the visible area and therefore had to be perfectly shaped :shock: . My creativity was challenged quite a bit to perform that task. Finally I took one of my welding clamps and modified it to a homemade hand held beadroller. 8-) 8-)
With this it just took me 3 minutes to form the recess around the whole aperture, without the time of taking this photos :roll: . I would never have expect that myself. But it worked in just one go.
so long
the Doc
turbocox
Post by turbocox »
8-) 8-) I like that, Very trick 8-) 8-)
GraemeC
Post by GraemeC »
Very ingenious - looks to have worked perfectly.
That tool would also be a lot easier to use than off the shelf jogglers!
Clubman gt
Post by Clubman gt »
You can buy a tool similar that you can put a ratchet on
You never cease to amaze me Doc. If it's not for your skill it's for your ingenuity.
What fantastic progress you are making!
Dearg1275
Post by Dearg1275 »
Necessity = invention. Keeps the mind busy. Fantastic.
InnoCooperExport
Post by InnoCooperExport »
Amazing stuff as usual Doc. I love a bit of tool bodgery, especially when it works so well!
Dr.Mabo
Post by Dr.Mabo »
The recessed aperture of the rear screen makes the panel only slightly stiffer. More strength comes only through an internal frame. For this I used a part of the former roof skin, which I had already cut out from the side areas. I formed several small stripes in the beadroller, some corner pieces and some straight ones. Welded together they formed the new inner window frame.
so long
the Doc
Charlynsane
Post by Charlynsane »
What a fantastic work as usual!! you make me feel like a dummy :D
Congrats mate!!!
ksione
Post by ksione »
Congratulations!!!! Very good job!!!! 😍😍😍😍😍
I want one!!!
Dr.Mabo
Post by Dr.Mabo »
Thanks for all your realy motivating response :oops:
The inner window frame should ultimately meet the rear parcel shelf. Thus I had to build it next. Starting with the side panels, which will later carry a pair of classic speakers.
Two small profiles will connect both side panels.
The center part of the parcel shelf will be made out of a wooden board. This will gain quick excess to the boot from the top. Of course it would be easier to simply build sharp edges at the corners. But I prefer rounded edges, because they looks nicer and it mad the shelf stronger. That’s why I took the trouble to build round corners in the profiles. ;)
so long
the Doc
turbocox
Post by turbocox »
8-) 8-) Oh Very slick 8-) 8-)
I want one too :cry:
Thanks for the updates Doc. It is great to see that you have thought your way through how your conversion will actually work as well as how pretty it will look when it is done.
GREAT progress.
mk1coopers
Post by mk1coopers »
Stuff like this always makes me realise how untalented I am :D :lol:
jayare
Post by jayare »
mk1coopers wrote: Fri Nov 06, 2020 12:34 pm Stuff like this always makes me realise how untalented I am :D :lol:
Ditto!
JR
AustinSe7en
Post by AustinSe7en »
You truly have the skills!
I salute you sir 😃
I hate metal work so what you/he is doing is the top of it in my opinion.
Kees
Charlynsane
Are you making a contest with Paul Wiginton? :D
Incredible skills Doc!! I'm truly amazed by your car and your sense of detail :D
