Just spent hours trying to start my old, well not so old actually (51plate) Renault Espace dci, eventually resorted to brake cleaner into the airbox inlet because I have no easy start.
It ran until the brake cleaner ran out, then after much dismantling etc. found out there was no high pressure fuel output so decided to see if a more prolonged run on 'alternative' fuel would coax the pump back into life....it ran flawlessly for about 5 minutes until the pump spray can, once full, expired.
Tried the high pressure pump outlet again ...no fuel.
After a quick calculation I figured out a way to attach the spray can to the intake and trigger it with a piece of string through the window.....then as a rough guide I reckoned it would do about 3 miles down the lane at a cost of approximately 52p per mile or if you prefer, just a bit less than treasury juice with all of the taxes added.
Not too sure of the effect on the environment though and suspect loud knocking noise from engine means a call to the breakers yard is imminent.
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
1 x chassis 007 1967 Cox GTM
