Re: Mini engine mounts-ggrrrrrr !!!!!
Posted: Tue Jan 15, 2013 8:43 pm
Well, I had cause to try this yesterday and it worked a treat, much much easier than the way I had been doing it, even my good wife recons I had been doing it the wrong wayguru_1071 wrote:Spider wrote:That's a damn good and simple way!Austin Cooper wrote:I leave the top bolt of the radiator bracket out and the bottom one a little loose. I then drop the engine in and fit the 4 bolts to the mounts through the subframe with the engine still suspended by the crane. I use a jack under the gearbox to lift it so I can fit the remaining long bolt.
I have used this method many times with genuine and non genuine mounts and it has worked every time.
Cleaver so-and-so![]()
Cheers for sharing
ive always done them this way as well, maybe this is why i never have any problems!!
Thanks Austin Cooper & Guru
