my 66 super D
Re: my 66 super D
Not got that far yet lol have nearly cleaned 46 years worth of oil and grime of the engine and only just started to venture inside , this is what the thermostat housing looked like both housing and water pump were so corroded parts of them crumbled to dust
Re: my 66 super D
This is what the block looked like with the gasket still in place you can see how suited up the pistons are
Re: my 66 super D
I have cleaned the head and re ground the valves now need to clean main block also took apart and cleaned the rocker assembly progress is being made slowly
Re: my 66 super D
Pic
Re: my 66 super D
those pistons aint that sooted up...actually they look quite healthy...
Re: my 66 super D
Progress is being made I am currently prepping the front end to be welded on but have been making progress with the engine
Re: my 66 super D
Front of engine
- miniminor
Re: my 66 super D
Did you strip the engine and box down any further or are you just popping the head back on to see how it runs?
2014 Freelander 2 SD4
Re: my 66 super D
Just gonna see how it runs I got it running prior to the head being stripped although it was really rough as you can see by the seized valves which are now sorted I haven't stripped it any further I have replaced the primary gear oil seal new clutch and water pump taking a gamble but not a major problem if engine has to come back out once installed
Re: my 66 super D
I wheel the old girl out for a bit of sun the other day better than trying to work in the garage slow progress on the new front end inner wings nearly sorted and measurements taken prior to removal of front panel ready to dry fit the panels and see how we'll they fit
Re: my 66 super D
it looks a bit embarrassed perched on that little trolley
Re: my 66 super D
Lol I no once I have restored the hydrolastic subframes and sprayed the under side it can finally go back on its wheels which would be excellent as this would free up a big space in my garage where the subframes are kept! ( room for more goodies ) I intend to do the L 2 B next year in it!
Re: my 66 super D
Making some real progress tonight I have aligned the bonnet to the scuttle got a good equal gap on that also removed the old front slam panel and dry fitted the new next job is to clean metal for welding then tack front in place for now at least so I can then look at aligning up the wings and inner/ outer a panels ! Bonnet is actually not shut its just on the secondary hook hence the gap!
- NotNormal
Re: my 66 super D
Making steady progress tonight I fitted the inner and outer a panel on the drivers side managed to get a good panel gap between the door and the a panel next to fit the wing then move to the other side it's starting to come together now !
Re: my 66 super D
Real progress tonight drivers wing now fully fitted and front end, now to fit the passenger inner and outer a panel and wing its starting to really come together now
Re: my 66 super D
I have now fitted the passenger side inner a panel and trial fitted the wing to find it wasn't sitting correct below the headlight when measuring and comparing to the previously fitted drivers wing I found that the L shaped piece of the wing had been welded in wrong now this has been rectified I can crack on with fitting it! Also had to remove headlight ring as this was out and in the pic you can see the panel in its correct position about 15 mm out of alignment to where it should have been
