Page 2 of 2
Re: Mk1 shell
Posted: Thu May 01, 2025 11:54 am
by mini_surfari
swifty wrote: ↑Wed Apr 30, 2025 8:16 pm
Mistake from all people M Machine , no battery cable on the floor pan and no tank support on the left side boot floor . also no captive nut .
Do M machine usually supply all of that? Heritage ones come bare other battery box.
Re: Mk1 shell
Posted: Thu May 01, 2025 6:06 pm
by Peter Laidler
Luckily, both Mini-Surfari and Swifty are gifted with the ability to work wonders with your panels as good tinnies. And that includes a bit of rectification and adding the odds and sods.
Great work from both of you over the years I say
Re: Mk1 shell
Posted: Thu May 01, 2025 7:42 pm
by swifty
Yes M Machine use a heritage boot floor and add there little mods to it .
Re: Mk1 shell
Posted: Thu May 01, 2025 7:48 pm
by swifty
So today I welded in one of Gordon’s boot floor panels , rubbed the boot floor down and clamped it up . Tomorrow rear panel
Re: Mk1 shell
Posted: Fri May 02, 2025 12:46 am
by 68Deluxe
Some gorgeous metalwork there!
Re: Mk1 shell
Posted: Fri May 02, 2025 8:00 pm
by swifty
I was going to fit the bottom half of a rear panel but I didn’t like the pressing around the lamp areas and other swage lines , so decided to fit a lower repair panel that ive had in stock for years . I may swage the joint as this gives me a bit more room for alignment.
Re: Mk1 shell
Posted: Mon May 05, 2025 8:28 pm
by swifty
Next stage rear panel preparation. Paint stripper and DA sander . Align up lower repair panel with boot floor and. I won’t weld yet as I need to try on a boot lid . Trouble is there’s a scaffold pole in the way ! .
Re: Mk1 shell
Posted: Tue May 06, 2025 1:56 pm
by swifty
Had to take the shell off the spit to check the bootlid gap . All ok so I can crack on with some welding now .
Re: Mk1 shell
Posted: Tue May 06, 2025 4:57 pm
by mini_surfari
Will you leave that panel joggled? Or will you cut and butt weld it?
Re: Mk1 shell
Posted: Tue May 06, 2025 7:55 pm
by swifty
I will leave it joggled . The metal can get a bit thin sometimes with a but weld that’s ground off . Plus it’s got the boot lid hinging from it . I will see if I can get a decent picture of the rear tomorrow.
Re: Mk1 shell
Posted: Wed May 07, 2025 11:29 am
by swifty
Rear panel welded
Re: Mk1 shell
Posted: Wed May 07, 2025 1:31 pm
by swifty
So swapping work to the front of the shell as I need to start welding the floor pan . So I’ve levelled the shell and dropped several plumb lines and marked the floor . Diagonally it all measures up ok , so next welding the front of the floor to the toe board .
Re: Mk1 shell
Posted: Wed May 07, 2025 6:09 pm
by Peter Laidler
That's exactly what I did on my shell with measurements and plumb lines, taken from the workshop manual. except my shell was astride 2x 6' fold-up tables, sat on a sheet of shuttering ply.
So far as I recall, using that method and a slave rear subframe only one drop line was slightly out of true.
GREAT work Swifty and a pleasure to watch your progress
Re: Mk1 shell
Posted: Thu May 08, 2025 7:15 pm
by swifty
Thanks Pete . .. plug weld on the floor pan . Also showing the underneath weld penetration. I’ve seen lots of bad welding over the years with people just filling in the hole . When I can get the spot welder in there I will add a few spot welds for a bit of detail . I was going to replace the quarters but it’s looking like I can save them with just a repair panel let in . Stripping the paint has revealed some earlier repairs .
Re: Mk1 shell
Posted: Thu May 08, 2025 7:42 pm
by Peter Laidler
That polyfilla on the rear sides looks horrendous. Interesting to see what is behind the stuff....., and at the bottoms
Re: Mk1 shell
Posted: Fri May 09, 2025 8:31 pm
by swifty
Not to much done today . Just a little patch
