Temp gauge
Been thanked: 22 times
Re: Temp gauge
Jasonking wrote: Wed Nov 13, 2024 6:49 pm Took speedo binnacle off to check gauges, now have lost clock illumination lights! Aaaaaarrrrrgggghhhh!! :shock:
Try running a temporary earth wire from one of the build holders to see if it is simply a bad earth???
Jasonking
Re: Temp gauge
Post by Jasonking »
Thanks for that, would that mean it’s the gauge that’s at fault then if no stabiliser fitted? Also does the little rocker light switch need to be connected for gauge lights to work?
Jasonking
Re: Temp gauge
Post by Jasonking »
Yes, having looked at top of speedometer there is a hole with a blackish jewel like thingy, so no voltage stabiliser fitted?
