Cooper S servo brake pipes for a dry car
Re: Cooper S servo brake pipes for a dry car
Hi all,
I ran my lines behind and under the servo with the idea of keeping the lines out of harms way, they took a bit time but certainly look better than some of the line set ups I've seen.
- Has thanked: 21 times
- Been thanked: 6 times
This picture was recently on Pete's Sporting Minis page. Owned by John Adair in 1995 a very original one owner1071 Morris with less than 30k
Not the clearest of shots but it may help the discussion It looks like a dry car which would seem to support Dave's theory that it's a wet/dry thing. So all1071s and pre- Sept '64 970 and 1275 to the side, and later 970/1275 over the top.You do not have the required permissions to view the files attached to this post.
- Has thanked: 75 times
- Been thanked: 64 times
What is that year car you are busy restoring in NZ Minime? What is the servo. Certainly a good job, like many of those shown here
- Toby
- Has thanked: 8 times
As Bob said it had nothing to do with an Austin/Morris thing. The route dispalyed as in Andy's and Bob's pic are the correct routing for a 1071.1071bob wrote: ↑Tue Feb 27, 2024 8:58 pm I don't think it was an Austin/Morris thing, my car is a Morris and it had the pipes clipped to the inner wing. I'm sure the pipe runs were changed when the hydro came along, there isn't a lot of room to route the pipes the original way with the hydro flexi pipe and bracket under the m/cylinder area. If you are making your own pipes to the early spec here are the pipe dimensions.
Dave, it might be worth mentioning for what kind of S you need to know the routing?
P.S. good to see copper unions being used Bob!
- Been thanked: 13 times
Hi tobyToby wrote: ↑Mon Mar 04, 2024 4:57 pmAs Bob said it had nothing to do with an Austin/Morris thing. The route dispalyed as in Andy's and Bob's pic are the correct routing for a 1071.1071bob wrote: ↑Tue Feb 27, 2024 8:58 pm I don't think it was an Austin/Morris thing, my car is a Morris and it had the pipes clipped to the inner wing. I'm sure the pipe runs were changed when the hydro came along, there isn't a lot of room to route the pipes the original way with the hydro flexi pipe and bracket under the m/cylinder area. If you are making your own pipes to the early spec here are the pipe dimensions.
It’s a dry 1275 S as I said in the first section, it is in the change over period dry to wet.
Dave.
- Been thanked: 38 times
Toby, Good to see copper unions being used Bob!
[/quote]
Not copper fittings, unions and nipples are Tecvac coated titanium,
that should get the 'original fitment police' upset.
Came off some old F1 calipers which were being scrapped years ago.
[/quote]
- Has thanked: 16 times
- Been thanked: 45 times
I think the dry 1275 build dates start around the time my car was built in Feb '64, and Bobs is March 64. The other one was June '64. I don't think they changed anything whilst they stayed dry. At least not from the research I have done. I also own a 64 switch over 850 with hydro, and yet early sun visors, so presumably a switch date car could run either set up?
Bob never does anything by halves Toby - his car is amazing
- Toby
Well close enough. However not many people appear to know about them being that colour.
@Andypen, am I the only one that was mad enough to have mine replated?
- Exminiman
- Has thanked: 41 times
- Been thanked: 31 times
[/quote]
Nice one Bob
Given the choice brass or titanium which one would I choose?
- Toby
The originals were copper plated otherwise they would have indeed been too weak
Hi Peter, car is 1967 mk1, servo is an Australian VH44.
