Ignition coils...
- Been thanked: 26 times
Re: Ignition coils...
Well I’ve just had a Remax coil failure ! … It’s probably done less than 450 miles . What do you do ? Purchased a while ago and put on the shelf as stock as we do … Shirley
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Porsche 997 turbo S
I am from Essex
- Exminiman
- Has thanked: 49 times
- Been thanked: 48 times
Maybe try one of these Elta coils ? Bit of a loud colour but could be painted…
No experience of them, maybe a call to Merlin to see if they they have been selling for long and get many returns ?
https://www.merlinmotorsport.co.uk/p/lu ... rrency=GBP
- Been thanked: 15 times
What actually goes in the coil to make it fail, anyone cut a knackered one open ?
I have written to them 3 times about my recent failures.
Haven't had a single reply.
They obviously don't give a toss.
- 111Robin
- Been thanked: 16 times
Have you checked the failed coil resistance to see if it's open circuit ?. It's not definitive but at least might give an indication of possible cause of failure. Testing the HT output is the best check but not easy. I can test coils to full HT voltage on my Sun tuner if it's of any help.
- 68&86auto
I've thought about stress testing coils until they fail but it would take a lot of time and money. It would also be quite complicated depending on the failure mode.
I wonder how much of "The Green Spark Plug Co" really is left after the merge with "DIY CAR SERVICE PARTS", maybe not much more than a name.
Look at this lie assuming it's who you contacted
The fact that there's no website or details for the Remax brand is a little bit odd. I believe it is owned/created by "The Green Spark Plug Co" but due to the lack of information it isn't certain. They put posts saying stuff like "Remax have released..." indicating a company other than themselves.
This is probably the bottom line.
I knew Tim Green when he used to sit at every Auto Jumble in the North of England with his stuff on a stand. Service & stock has only got worse since those days, a takeover / company sale would probably explain the woeful after sales service.
- 111Robin
I see that Distributor Doctor sells the "made in India" Lucas coils, maybe they're ok ?. Who knows. I'm guessing that if you have a failed coil they will try to say that your setup caused the failure, easy way out and not something they will be willing to disprove. Are Bosch coils any good these days ?, they used to be the be all and end all but again I have no idea where they are made these days, we are at the mercy of global (ie. cheap) sourcing.
- Exminiman
These Bosch coils look ok , albeit a bit dear https://www.swiftune.com/parts-shop/ign ... oil-2.html
.....EDIT just spotted they are out of stock
- 68&86auto
Bosch are no longer good. There was one model that became the one to use but even that has poor reviews now.
- 111Robin
Yes I've read about the current Bosch Blue coils manufactured in Brazil/Mexico ?. I'm not saying all such items are rubbish but it does leave it open to pot luck somewhat.
- Exminiman
Fooking hell, does nothing work these days.....
we are all doomed
we are all doomed
- Has thanked: 116 times
- Been thanked: 101 times
Maybe it's time to get The Distributor Doctor on board and get some made. His stuff is always pretty good
- 111Robin
Peter he sells the "made in India" "Lucas" coils, given his reputation maybe that's an indication that they aren't that bad, who knows ?.Peter Laidler wrote: ↑Wed Aug 07, 2024 4:33 pm Maybe it's time to get The Distributor Doctor on board and get some made. His stuff is always pretty good
- Has thanked: 166 times
- Been thanked: 52 times
I believe they were good, but they and just about any other Bosch Ignition Coil seem to be NLA now.111Robin wrote: ↑Wed Aug 07, 2024 2:03 pmYes I've read about the current Bosch Blue coils manufactured in Brazil/Mexico ?. I'm not saying all such items are rubbish but it does leave it open to pot luck somewhat.
Has anyone tried Mallory Coils lately ? Used to be made in the US (and still might be). Very popular and was (still is ?) well regarded brand.
https://www.holley.com/brands/mallory/
MSD is another highly regarded ingnition brand;-
https://www.holley.com/products/ignitio ... ce_street/
Accell is another, but I know less about them;-
https://www.holley.com/brands/accel/pro ... ls/street/
It appears some ignition coils are filled with oil and other with resin.
My own view is the resin ones are likely to be less reliable. The resin needs to be mixed with the greatest of care so it's not contaminated and in the right proportions and then the coil needs to be held under vacuum after the resin has been poured to rid it of air bubbles. Given where these seem to be made these days, I think this aspect would be a fail on all accounts. The other issue with many of these potting resins is that they can shrink over time and with heat cycling and so will eventually crack.
Oil, while there's a risk of the leaking, avoids many of these issues.
- snoopy64
- Has thanked: 67 times
- Been thanked: 13 times
I’ve had a Pertronix coil from the Dist Doctor for about 10years and boy it has a kick! If he is selling repro Lucas I suspect he has tested them thoroughly but no harm in asking…
Kevin
Kevin
- Been thanked: 9 times
Have used Viper coils for a few years now on mine and customers cars. No problems.
- 68&86auto
I've had a Viper dry coil fail. It did however last longer than any other new coil I've used.
- Has thanked: 13 times
- Been thanked: 11 times
Have had great results with an NGK coil, car definitely started up quicker on an old lucas one that is date stamped 1979 than a gold Lucas sports, and the same instant starting with the NGK.
It's probably 4 or 5 years since I bought it but only cost £22.
- timmy201
- Been thanked: 34 times
I bought a cheap and cheerful standard coil from a mini auto electrician here. It's worked perfectly for 8 years (along with the cheap electronic module)
Recently I have got a Bosch SU12R coil and no complaints so far. They also sell the SU12 for non-ballast systems.
