Engine recipe..
gs.davies
Has thanked: 75 times
Been thanked: 77 times
Re: Engine recipe..
Post by gs.davies »
What I discovered today was that the gap between third and fourth is too wide. And while I’d like a 2.9 I’m not convinced an 1100 would carry that up long drags at 70 mph plus.
What can be done about narrowing the gap between third and top? S ratio?
Alex
Re: Engine recipe..
Post by Alex »
mk1 wrote: Wed May 31, 2023 2:38 pm Q: What "Ultra Wide Ratio" gear sets are currently available?
Q2: What are "two O/D drop gears"?
Metro HLE / MPi Mini are the wide ratio gearsets.
Metro HLE (and others) had a primary gear with an extra tooth (NOS one in a box on my desk) and the gearbox input gear had one less tooth. The two combined are worth an FD ratio, which is how Steve effectively has a 2.56 fd.
Alex
Re: Engine recipe..
Post by Alex »
gs.davies wrote: Wed May 31, 2023 9:53 pm What I discovered today was that the gap between third and fourth is too wide. And while I’d like a 2.9 I’m not convinced an 1100 would carry that up long drags at 70 mph plus.
Both of my 1100s will pull a 3.1 with no trouble at all, and the 1186 will spin the wheels in 2nd gear...
A 2.9 would be no problem at all.
MiNiKiN
Has thanked: 93 times
Been thanked: 31 times
Re: Engine recipe..
Post by MiNiKiN »
I reckon it is worth to consider what the use case is:
  • endless flat Norfolk planes filled with cabbage scents
  • countless corners and inclines in the peak district
  • the daily commute from NW to SE-London right through the centre
for the latter the 2 the 2.9 FD might be a bit annoying
CooperTune
Re: Engine recipe..
Post by CooperTune »
Thanks Alex for filling in the blanks. The gear set like the A+ having a single tiny groove machined into teeth has two tiny grooves. The 30 tooth primary has a single groove and the 29 tooth first motion gear has a single groove in the shoulder between teeth and ball bearing. I also has a NOS primary new in the box and I paid $238. US for it several years ago. To be fair my 1990 Rover Cooper has a 1293 cc with SC/CR, 4.13 CWP, 11 t0 1 CR and a 285 Piper cam, twin HIF 38s. Steve (CTR)
