Sorry to be asking the same or similar question again but can you add a voltage stabilizer to a non voltage stabilized gauge? I have a ‘61 fuel gauge with the silver face which is non stabilized and a spi/mpi fuel tank with the stabilized sender. I’m not sure if there would be a silver stabilized fuel gauge available, would there? Maybe even fitted to a non mini car?
If they did make a stabilised silver fuel gauge it’d be very tricky to find, as the silver face finished up about the same time as the stabilised system was introduced
Mark 1 Peachy above. Have you ever considered stripping the silver face from the gauge and putting it onto a later voltage instrument stabilised gauge. Dead simple to do with a fuel gauge........, even easier than the temp gauge.. This sort of job would be an everyday bread and butter job in an instrument workshop
Hello Peter, thanks for your reply. I had thought this might be an idea I need to look into. Would any mini fuel gauge after ‘64 be voltage stabilized?
I think so, yes. But be careful when handling or stripping the gauges. We found that the pointer/needle cheap Smiths gauges had a tendency to 'jump-the-track'.
