Page 2 of 2
Re: Magnum alloy bonnet skin
Posted: Thu Jul 28, 2022 12:37 pm
Received mine & I'm very pleased indeed. I have been told that there is no chance of them doing the inners though
Posted: Thu Jul 28, 2022 12:51 pm
by Nick W
Just us a steel frame and fill it with speedo holes
Posted: Thu Jul 28, 2022 1:03 pm
That's the plan, then find some kind soul to paint it for me of course
Posted: Thu Jul 28, 2022 1:06 pm
by Nick W
Haha who might that be...
Hope you saved some paint for it
Posted: Thu Jul 28, 2022 1:07 pm
I wonder, Now let me think. . . . .
Posted: Thu Jul 28, 2022 11:07 pm
by lomin
Hi, my OBL45F restoration is being done in epoxy two pak. The base sealer for the steel shell is a different product to what seals the aluminium panels. Apparently corrosion can occur under the paint if you do not use the correct aluminium one. The body shop was not aware of that, it was a paint manufacturer who pointed it out. The car should be painted in a couple of weeks. cheers Lindsay
Posted: Fri Jul 29, 2022 8:35 am
Would love to see some pictures of that!
Posted: Fri Jul 29, 2022 9:52 am
by Ronnie
lomin wrote: ↑Thu Jul 28, 2022 11:07 pm
I believe it is just a self etch primer needed, perhaps Nick W could comment.
Posted: Fri Jul 29, 2022 11:45 am
by Nick W
Yes I use etch primer,... thing I find with aluminium, it it can be contaminated very easily, After sanding it need primer on straight away, as is oxidise quickly. Best way to ensure a perfect key for the primer is to carefully blast clean the alloy, obviously at a low pressure/ fine glass bead . I handle it with gloves on once it's ready for primer, as sweat will mark it, causing problems months after its painted.
Posted: Thu Sep 08, 2022 6:10 am
by 850south
is this the Magnum one at Minispares? MS114ALLOY - ALUMINIUM BONNET SKIN (NO LIP) ...and what do they mean by No Lip?!
Posted: Thu Sep 08, 2022 7:30 am
by imack
850south wrote: ↑Thu Sep 08, 2022 6:10 am
No mk2 type lip on the front edge to mount the chrome trim.
Posted: Thu Sep 08, 2022 7:40 am
And it's the same panel. Made by Magnum & sold by Minispares amongst others.
Posted: Thu Feb 02, 2023 9:22 pm
by 850south
Thank you! Slow on the reply, but I did purchase one:)
