Page 2 of 2
Re: Water pumps
Posted: Fri Dec 13, 2024 9:14 am
by m1n1man1275
Hi All, I have a cast iron pump that needs refurbishment. does anyone know if E P services are still going? i have messaged them but no response, wondered if anyone had had one done recently. failing that a kit to do it.
Cheers John.
Re: Water pumps
Posted: Mon Dec 16, 2024 9:08 am
by Exminiman
indigo wrote: Sun Dec 01, 2024 10:21 am In the process of fitting a new Minispares EVO pump and want to check the impeller clearance, casting flashings, etc.
Should the impeller clearance be 10 thou as per the original cast iron pumps? It definitely looks more than this.
Check the holes in the pump that the locating dowels go into are deep enough...or it wont seal to block....guess how i know...
Re: Water pumps
Posted: Mon Dec 16, 2024 9:25 am
by Peter Laidler
Maybe minimk1man could contact our very own Andrew1067 about getting is original cast pump rebuilt. Andy might know someone..... If I read the previous posts correctly
