Fan belt alignment
InnoCooperExport
Has thanked: 4 times
Re: Fan belt alignment
Post by InnoCooperExport »
Peter Laidler wrote: Wed Jun 23, 2021 9:57 am Been following this saga on and off and it's clear that you have a mix-and-match dynamo/fan/pulley fitted to your car. However good your pics and try as we might I don't think that we are going to fix your prob from afar. It needs either a) replacement parts, b) a replacement correct dynamo or c) a lathe to start machining your parts to suit - or in the case of the spacers, to machine new ones to suit what you've got (which would be my tight fisted but hands-on approach!!)
Not just you, I'd vote option c as well! 3 minute job on a lathe.
Coatescooper
Post by Coatescooper »
Well thank you to everyone for there Input and in particular Andrew1967 for your very helpful photos.
Whilst the dynamo manufacturers, and some other sources are all telling me it’s the correct item, it is however clearly not quite right. The pulley whilst it might not be quite right, it is giving me the correct offset, the issue clearly stems from the spacer not going into the Dynamo far enough. I have looked at a few different machining options and I don’t really have the correct equipment to hand to undertake this work, plus this would be quite time consuming.
I have therefore just purchased a pack of 22x15x2mm washers, 2 or 3 of these to pack the dynamo fan out should in theory sort all my issues out. There due for delivery tomorrow, so let’s see!
Sounds like a plan and glad to help. :)
Let us know how it all goes .
Coatescooper
Sorted. I’ve managed to get the pulley about 4mm further in, I was targeting 5mm though.
Three washers did the trick, they were a perfect fit around the Dynamo shaft yet still fitted into the recess on the Dynamo. Two washers would of been ideal, but the dynamo fan is a little misshaped, I might have to replace the fan or grind down some of the fins
Thanks for those pictures as they really helped in understanding where the issue was
Excellent .. glad you have it sorted :D
If you need a replacement fan, let me know, I have one I can spare.
