Barn find MK 2 Rally car
e-type
Re: Barn find MK 2 Rally car
Post by e-type »
ADO 16 radiator
e-type
Post by e-type »
Last Friday I picked up the rest of the parts, that came with the car. It looks like the old war horse has been used in anger :-).
e-type
Post by e-type »
More evidence of a hard life :-) cam follower and pistons
e-type
Post by e-type »
It will need new brake parts, to get it going, but luckily i found these in some of the many boxes with spares that came with the car
e-type
Post by e-type »
maybe I am lucky, this box was among all the many parts that came with the car :-)
e-type
Post by e-type »
Saturday, I pulled out the engine.
e-type
Post by e-type »
Reason why they stopped using the car: broken remote housing, and diff cover
e-type
Post by e-type »
Are you nuts!! , Cooper S thin flange engine block
e-type
Post by e-type »
Drop gears with Timken bearings, and nicely engineered plate :-)
e-type
Post by e-type »
After honing the rusty cylinders, the pistons cam out, nice polished Cooper S conrods
e-type
Post by e-type »
EN40B 1275 S crank and 731 cam
Nice!
All looks well recoverable.
e-type
Post by e-type »
Genuine LSD, but never seen these output shafts before.
According to the seller, the driveshafts, should be Jack Knight, but the output shafts looks like a mix of hardy spicer and pot-joints.
Any info on this please?
Better pictures may help.
r.tec
Location: Bad Muenstereifel (D), 30km to The Ring, 80km to Francorchamps
Has thanked: 7 times
Post by r.tec »
Do not know exactly but I remember that in one of the ancient David Vizard "Mini Technical News" he wrote that someone in Denmark used modified Saab driveshafts. Have to look through all my copies.
Brian Thurston
Post by Brian Thurston »
Got the perfect engine/box thin flange just up the Kattegat! Thurston@online.no eller 004793887331 mvh B
minimad
Post by minimad »
Looks like someone has welded a turned down pot type joint onto a salisbury LSD type output shaft , you can just see the weld .
e-type
Post by e-type »
minimad wrote:Looks like someone has welded a turned down pot type joint onto a salisbury LSD type output shaft , you can just see the weld .
Yes after cleaning, I can see, that is what has been done.
Maybe only the shafts are Jack Knight. :-)
e-type
Post by e-type »
There is still evidence from the last Rally it did some 35 years ago in Faxe Kalkbrud. Faxe is the town, where they make Beer, but also have a large limestone quarry. The white stuff is everywhere under the car. :-)
e-type
Post by e-type »
I think it will need a recharge :-)
