The trick with fitting points is simply remove the distributor and do it properly.Andrew1967 wrote: ↑Mon Jun 04, 2018 9:26 amA magnetic one at that Davekit of bits wrote:The trick with fitting points is an 18” long screw driver!
1977 Mini Pickup
- 850man
Re: 1977 Mini Pickup
You forgot no.1 use for the VW van.
I can’t believe you posted vw pictures on the forum
Converted the VW to a camper last year - that's why the Pickup didn't get it's discs fitted last winter
Had to show I'd been doing something and not just neglecting the Mini!kit of bits wrote: ↑Wed Mar 18, 2020 12:39 pm You forgot no.1 use for the VW van.
JR
