Page 2 of 2
Re: Coil Spring Clutch nightmare
Posted: Sat Dec 26, 2015 3:58 pm
by Rich997
Attached a photo of the clutch arm.
Do you think the wear / possible bend would be enough to cause the issue?
Posted: Sat Dec 26, 2015 4:53 pm
by Andrew1967
It's definitely worn and will cause some clearance issues. Not sure about the angle. If it was mine I would weld and reprofile the ball.
If the hole in the plunger is also ridged, it will exacerbate the problem further.
Posted: Sat Dec 26, 2015 7:48 pm
by pad4
it does look bent as well
pad
Posted: Sat Dec 26, 2015 8:54 pm
Worn and Bent - bonus!
Replace the plunger & all the pins too.
Posted: Sat Dec 26, 2015 10:05 pm
by mini63
Rich997 wrote:Attached a photo of the clutch arm.
No....
and from memory I recall occassionally putting a thin section shim washer under the 'press on' type release bearing to reset the clutch slave piston location.
