Page 2 of 3
Re: twin tank venting
Posted: Mon Apr 08, 2019 7:56 pm
by Cammsjb
All the tabs are spot welded on a mk2
Posted: Tue Apr 09, 2019 1:06 am
by Johnny
Vertical clips going down the right side.
I never really noticed these until the other day.
The are not riveted or screwed.
They snap into a hole in the seat back.
Posted: Tue Apr 09, 2019 11:58 am
by gogsymac
Johnny wrote:Vertical clips going down the right side.
Johnny - thanks for confirming. I wondered why my car didn't have any clips for the right hand tank there. Now I know. Never seen these clips before and I wonder where I can get them.
Posted: Tue Apr 09, 2019 12:05 pm
by Peter Laidler
Aren't these the little clip thinggies that hold the overflow pipe to the side of the rad?
Posted: Tue Apr 09, 2019 12:11 pm
by Nick W
id say they are a bit smaller than the over flow clips
I recognize them but cant think where from?
Posted: Tue Apr 09, 2019 12:12 pm
by winabbey
I believe the part number is 17H9524, in case that helps.
Posted: Tue Apr 09, 2019 2:15 pm
by gogsymac
Peter Laidler wrote:Aren't these the little clip thinggies that hold the overflow pipe to the side of the rad?
I just checked. They look very similar to the radiator overflow pipe clips but not quite the same. The bit that clips through onto the seat back is shaped differently.
Posted: Tue Apr 09, 2019 2:31 pm
Pete wrote:It was to help prevent siphoning the fuel off if the car was parked on a tilt if I remember correctly?
You do, it was & if you don't cross the pipes over watch out!
About 30 years ago I had to stand & watch a MK2 S burn out because I didn't know about this.
Posted: Tue Apr 09, 2019 4:33 pm
by Andrew1967
Do you have a picture of the part of the clip that fits onto the bulkhead Gordon ?
I have some NOS clips from an old BMC garage and there could be some in with them - probably not but you never know ;)
Posted: Tue Apr 09, 2019 6:42 pm
by gogsymac
Andrew
I don't unfortunately. On my car which had a factory fitted right hand tank there were no clips or tags. I was puzzled about that and so during the restoration of the boot area I welded up all the holes which didn't look right. I suspect I will have welded over the holes which the clips fitted into. The clips in Johnny's photo do look very much like the radiator overflow clip.
Posted: Tue Apr 09, 2019 6:52 pm
by Andrew1967
That's a right bugger if you have welded up the factory holes Gordon :(
The radiator overflow clip has teeth to grip onto the cowling, in a similar way to the side to side brake pipe clip on the front subframe.
Anyone able to post up a pic of the back of the clip ?
Posted: Tue Apr 09, 2019 7:07 pm
by gogsymac
Andrew1967 wrote:That's a right bugger if you have welded up the factory holes Gordon :(
Not the first time I have welded up holes that should be there. You learn as you go along I suppose.
Posted: Tue Apr 09, 2019 7:27 pm
by Andrew1967
We've all done it, but at least you can re-drill when the faux-pas is discovered :oops:
Posted: Tue Apr 09, 2019 9:28 pm
by AndyPen
Me too, less annoying than the two holes I didn't get welded up where the old rubber handle thingy kept the racing fibreglass boot (with no handle) closed! I am putting grommets in mind you as when all said and done, it is part of the car's history.
Posted: Tue Apr 09, 2019 10:01 pm
by Johnny
Here is the back side of the clip, I pushed it out of the hole. This is the lower one. Seems to have dissolved the old vent tubing and bonded together with the remnants. Not a very good venting system.
Posted: Tue Apr 09, 2019 10:13 pm
by Andrew1967
Thanks Johnny, I'll have a look and see what I've got over next couple of days or so.
Certainly looks sort of familiar ...
Posted: Tue Apr 09, 2019 10:37 pm
by gogsymac
Andrew1967 wrote:Thanks Johnny, I'll have a look and see what I've got over next couple of days or so.
Hopefully you do have something like that in your stash of parts. I would certainly be interested if you do.
Posted: Thu Apr 08, 2021 9:02 am
by steve1071
Anyone know the change over date from the bolted clips to the welded tabs?
Posted: Thu Apr 08, 2021 2:48 pm
by 360gts
steve1071 wrote: Thu Apr 08, 2021 9:02 am Anyone know the change over date from the bolted clips to the welded tabs?
Here are some pictures of my Nov 5 built 1275...(complete with factory paint runs).....has the slide in clips.
I suspect that these were eliminated and welded tabs were fitted with the introduction of the RH tank as standard equipment in Jan. 66
P/N 13H9524.....I have a sneaky suspicion that this clip was something that was used on other vehicles. I seem to recall seeing them ...somewhere!
The fact that they appear to be painted green....perhaps they were used on the Lan Rover....just a thought!!!
Pretty sure BMC wouldn't have produced the clip for a small number of RH tank cars.
Posted: Thu Apr 08, 2021 3:47 pm
by Peter Laidler
These small clips and the like wouldn't have been manufactured by BMC but very probably brought in from a small press shops. I know that this is true of a similar round spring clips, also painted green (and blue for the larger size!) used to hold the fuel hoses on MG cars
