Page 2 of 9
Re: My Morris Traveller Project
Posted: Wed Oct 28, 2015 4:54 pm
by swindrum
NicholasUpton wrote:Be carful with the clean strip pads on the angle grinder, as they can act like a shrinking disc and cause panel distortion, that ends up being more work. We normally use holdtight 102 and water to scrub by hand after using the stripper, this will neutralize and protect the metal while you are doing body work.
Otherwise you are looking good. Keep the progress coming.
Very good tip! I keep the pad moving and don't sit it in any one spot for any length of time. So far, I have done all 4 doors and they are still nice and straight!
I am not sure what holdtight 102 is though...
I have been rinsing with lacquer thinners to remove the residue. I am loathe to put water near bare metal.
Last night's progress was around the back, there was some damage to the rear lip, loadspace support, and valance. I cut the damaged area out and started fitting the repair panels. I think I will replace the valance as well.
Here is the undamaged side prior to cutting, but with the loadspace support removed
And the damaged side, note all of the filler to re-form the step and all of the brazing
Re: My Austin Countryman Project
Posted: Wed Nov 04, 2015 12:40 am
by swindrum
I realized that the only way to do this right would be to remove the rear valance and corners, then cut everything back to good metal.
The panel where the internal tank had been installed had been pounded to allow the tank to fit, so that was cut out as well.
A panel was made to replace it.
Old and new
Tacked in
Repair for right side inner corner
Fitted up with new rear step
New rear valance and corners offered up
Also trial fit of rear loadspace support
Posted: Wed Nov 04, 2015 12:44 am
by swindrum
Over the weekend I had a request to paint a set of tanks for a Mk1 Cooper S
I decided that if I was mixing up a batch of paint and moving things around the shop, I would do some other things as well.
I grabbed everything that was in my "already been blasted" box next to the sandblaster, as well as a couple Mk1 heater assemblys I have been working on. One for the Countryman and one eventually for the Van
Posted: Wed Nov 25, 2015 7:07 am
by swindrum
Well, work has slowed to a crawl, or more accurately, a hobble... We had a death in the family, which is always a hard time, and then 2 weeks ago I broke my kneecap and buggered my leg in a cyclocross crash...
Not all has been lost, I have taken this time to do some cataloging and inventory and ordering parts I thought I had.
I have been able to weight-bear as of this weekend, so have been standing in front of the sandblasting cabinet. Have gotten loads cleaned up
Posted: Thu Nov 26, 2015 6:06 am
by swindrum
I realized I forgot to post a photo!
I didn't realize I had 5 sets of external hinges, so pretty excited about that. I have ordered hinge pin kits and the bushing tool. So the Traveller, the Cooper, and the Van will have fresh hinges.
Posted: Thu Nov 26, 2015 11:49 am
by woodypup59
How many door hinges do you need on this car ?
Posted: Thu Nov 26, 2015 4:30 pm
by swindrum
woodypup59 wrote:How many door hinges do you need on this car ?
It's the very rare Countryman Limousine, seats 12...
Posted: Thu Nov 26, 2015 8:09 pm
by swindrum
So, in my effort to find things to do while my knee heals up. I set about testing and inventory-ing my starters. I figure I will see if I have the correct date codes for the cars I have here, I need a 62 for the 850, a 63 for the 997, a 65 for the Countryman and a 68 for the van.
So far I have found
11-54 (Morris Minor?)
05-63 (997 Cooper)
12-64
12-64
09-65 (Countryman)
11-65
03-66 (Possibly spoken for)
09-68 (Van)
01-69
02-69
04-69
03-70
09-73
04-75
28-75
44-78
So I have come up short for a 62 and a 63, but I suppose it isn't super important.
So I set about taking one apart in preparation for restoring
In the past, I have always just found suitable replacements when a starter goes bad, so I have never bothered rebuilding them. So it will be a learning experience.
Come with me on this journey of wonder, won't you?
So first off is bendix removal, this was all new to me so I made it up as I went along
You will need to be able to squish the spring in order to remove the c clip that keeps the retainer
I am sure there is an easy way to do this, but I settled on Vise-grips, they do the job, but, be aware they do come flying of at light speed every so often
The retainer will be stuck, so I used a spark plug socket and a hammer to gently tap it, exposing the c-clip
Which I then pried off with a small screwdriver, keep your fingers clear in case the vise grips let go...
Then the entire bendix should come away from the shaft
Next, remove the 2 long bolts
The armature will pull out, be careful not to damage the windings
Once it was all apart, I cleaned up the shafts and splines on the wire wheel, the next stop is the auto electrics place to test the armature(s), I plan on taking a bunch in (all the Mk1's) and getting them checked.
Posted: Thu Nov 26, 2015 9:59 pm
by smithyrc30
You are a braver man than me.
I use an old screw type valve spring compressor.....
Posted: Thu Nov 26, 2015 10:13 pm
by java gt
I was given a bendix spring removal tool many years ago,have still to use it.
Posted: Thu Nov 26, 2015 10:22 pm
by swindrum
java gt wrote:I was given a bendix spring removal tool many years ago,have still to use it.
I do have about 12 more starters here...
Although the Vise-grip method seems to be working fine, but I am sure once I become complacent it will bite me...
Posted: Fri Nov 27, 2015 6:06 am
by Dr.Mabo
Make sure there is no bearing play on the shaft.
I have a lovely reconditioned starter which turns freely without load but with some play in the shaft.
When it is installed and engaged to the fly wheel, the shaft is pushed to one side within the housing. Thus the starter can't turn freely anymore and doesn't has enough power to start the engine. Due to the fault symptoms I was searching on the wrong palce for a long time. The system behaves like a flat batterie but eventually it was the reconditioned starter.
so long
the Doc
Posted: Sat Nov 28, 2015 7:32 pm
by Craig
Swindrum , if you would like a spring compressing tool let me know and I would be happy to send you one ! FOC.
Would need your address of course .
Craig
Posted: Sun Nov 29, 2015 7:05 am
by Craig
Here's the starter tool
Just made from a couple of 1" Flat washers and a couple of 1/4 NF nuts.
Craig
Posted: Mon Nov 30, 2015 6:47 pm
by swindrum
Craig wrote:Here's the starter tool
Craig
Well, that is very clever! I got 5 armatures tested over the weekend and they all tested good!
Blasted the cases and will hopefully get some paint on them this week.
Posted: Sat Dec 05, 2015 8:53 pm
by swindrum
Posted: Sat Dec 05, 2015 9:21 pm
by Gareth Brandt
That's porn.............................
Posted: Sat Dec 05, 2015 10:24 pm
by JC T ONE
Gareth Brandt wrote:That's porn.............................
Agree
Posted: Mon Dec 07, 2015 3:40 am
by swindrum
Awe shucks, thanks...
I painted a couple Dynamo cases and a few other engine bits as well as a 998 Cooper engine. Everything looks pretty nice. Today I was able to assemble one of the Dynamos and finish dis-assembling the rear trailing arms. All the bits went into the blaster and will be painted in the next few days. Once this round of stuff is painted, I will be back to grinding and welding and making dust.
My knee has been healing up nicely, so I am hoping to return to the body work this week . I want to get the welding sorted before Christmas
Posted: Tue Dec 08, 2015 5:05 pm
by swindrum
Dynamo before
Dynamo after
998 Cooper Engine
