Page 2 of 2
Re: wet to dry suspension
Posted: Fri Jan 09, 2015 12:58 pm
by coopers1968
Dr S wrote:Hmm, where does that bolt in from? They look familiar but they weren't attached to the subbie when it came out. I've never seen them on the car, but I've pulled out plenty of hydro units.
Either that or you can pull the unit and leave them in place?
hi doc,
the pin comes out from the hydro unit. i guesss its meant to fall out or is it meant to be fixed in tightly to the hydro unit?the pin of the other hydro unit seems to be intact well strong.
thanks
Posted: Fri Jan 09, 2015 1:06 pm
by Dr S
They slide in and out as a close fit, however they seem to corrode in place. I have several that are serviceable with the pin in. I'd leave it be.
If you look in the other unit you'll see there is nothing to find when its removed. Minimail sells them for a couple of quid from memory if you want to drill it out.
Its held in place by the weight of the car once its on its wheels.
Posted: Fri Jan 09, 2015 1:19 pm
by coopers1968
cheers doc, i just need to know how deep it goes into the hydro unit in order not to over drill the pin out and make a catastrophe!
Posted: Fri Jan 09, 2015 2:24 pm
by olddad
My '65 S was converted in the '70s and when we rebuilt the brakes the standard rear brake hose was wrong-too short. Got special hoses made for this conversion from 7 Enterprises here in the states. They don't seem to list it, but they knew exactly what the problem was and provided the hose. This allowed the use of the original swing arms which I was reluctant to replace in case I ever restore the wet system.
Posted: Fri Jan 09, 2015 2:33 pm
by Dr S
I've had this issue with a new set of goodyear hoses, apparently the wet routing isn't the same as the dry routing. Pictures to follow once I've replumbed it.
