Mk2 Cooper
Callum
Re: Mk2 Cooper
Post by Callum »
Got the step fully welded at the weekend then started on the repair to the bottom of the quarter, got it tacked in tonight.
Image[/URL]
Image[/URL]
InimiaD
Re: Mk2 Cooper
Post by InimiaD »
Fair play to you. That's a major restoration you have going on there and considering it's your first attempt the results so far look excellent.
Regarding the boot floor being a tight fit, I read somewhere that the boot floor pressings were made 10 mm wider between the wheel arches. Sometime in the late 70's early 80's.
Callum
Re: Mk2 Cooper
Post by Callum »
Got it fully welded tonight, very pleased with how it came out thought there might be a lot of distortion.
Callum
Re: Mk2 Cooper
Post by Callum »
Got the other side tacked in tonight
Callum
Re: Mk2 Cooper
Post by Callum »
Finished welding the drivers side at the weekend, still need to linish it fully
Took it back off the spit again so I can get inside to finish welding the floor and arches, and ready for the front
bulkhead repairs. Finally got rid of the horrible bracing too
Callum
Re: Mk2 Cooper
Post by Callum »
Finished spot welding the heel board to the boot floor on Saturday. Waiting for my angle die grinder to arrive
before I can finish cleaning to welds at the rear so I started on the front bulkhead. There is heavy pitting on most
of it so would need a lot of different patches making for it to be good again. I don't think I could make a good job
of it so I'm going to replace the whole thing with another one that I have. Cutting it down to just the part I need...
Still needs a bit more work and then sand blasting, don't know if I will do it myself or pay someone else to do it,
I hate sand blasting!
Callum
Re: Mk2 Cooper
Post by Callum »
Last week I got the bulkhead tidied up and ready for sandblasting, will hopefully get that done at the weekend
Also added a load of bracing to stop anything moving and a couple of jigs for the toe board and cross member so
everything goes back in the right place. Got the old bulkhead cut out tonight so there's no going back now. Maybe
went a bit mad with the bracing :-D
Then tested the new bulkhead to check it fits which thankfully it does
Callum
Re: Mk2 Cooper
Post by Callum »
Got the sand blasting done at the weekend, took all day Saturday
Primed it yesterday, ready for a few repairs now
Callum
Re: Mk2 Cooper
Post by Callum »
Had some more panels delivered last week. Been working on the toeboard panel over the weekend, you can only
buy the late type ones and the early ones are slightly different so been making some changes to it, still some more to do
Callum
Re: Mk2 Cooper
Post by Callum »
Got the toe board finished yesterday, I made the subframe strengthening plates a bit bigger and out of thicker steel
than they are originally, don't no if that was needed but the original ones don't seem that substantial
Callum
Re: Mk2 Cooper
Post by Callum »
Got a few spot welds on the toeboard tonight, it lines up with the jig so nothing has moved. Will finish welding it in
and then start repairing the bulkhead
Callum
Re: Mk2 Cooper
Post by Callum »
Been working on the bulkhead for the past couple of weeks, there hasn't really been anything update worthy until
tonight. Welded a plate in at the end where it joins the toeboard/inner wing, forgot to take a picture of it before, needs finishing off when the cross member repairs are finished
Then started on the bottom of the cross member
Before
Repair made up and tacked in
Fully welded, blew a couple of holes along the top might of been a bit thin but probably just down to me still
learning to weld
Linished, got to add the holes for the subframe bolt and hydrolastic pipe
Made a new strengthener for where the subframe bolts pass through the cross member
Repaired one corner where it joins the windscreen scuttle
Thats it for now, cheers
Callum
Re: Mk2 Cooper
Post by Callum »
Finished repairing the bulkhead over the bank holiday forgot to take pictures though. Got it welded to the toeboard tonight
Took the skins off the doors over the weekend and they are worse than I thought, the window surround needs
splitting from the rest of the door frame really so I'm going to try and find another pair before attempting to repair
these ones. Some pictures showing the rot
Callum
Re: Mk2 Cooper
Post by Callum »
Had planned on keeping the original upper dash rail but it was quite pitted along the windscreen seam so went for
a new one. The new panel is made for a late mini, I didn't know but the heater vents are further apart on the older
ones so yet more cutting and welding new panels
Callum
Re: Mk2 Cooper
Post by Callum »
Got the upper dash rail welded in last week as well as the inner sill closing panels on both sides
Finally found some doors so went to pick them up on sunday. They are very good and still have their original skins
which wont need any repairs , came off an early 60's racer and have supposedly never been on the road.
The drivers side is a good fit with an even gap most of the way round but the passenger side isn't so good. The back
edge of the skin touches the B pillar whilst the window frame is too far away. The pictures don't show it very well...
Not really sure what to do with that, is it a case of grinding the door skin lip back and then running a weld up it and keep going until there is an even gap? Cheers
Callum
Re: Mk2 Cooper
Post by Callum »
Been working on the drivers side A panel tonight, its cut down and fits now so hopefully can weld it in tomorrow.
Callum
Re: Mk2 Cooper
Post by Callum »
Got the A panel welded yesterday, got to turn it around and do the other side now
Callum
Re: Mk2 Cooper
Post by Callum »
Callum
Re: Mk2 Cooper
Post by Callum »
Not been able to do much just recently, I was working on the front but still need to buy the drivers side inner wing
and the scuttle before I can test fit all the panels and carry on welding. But I can't buy the panels as i'm very short
of spare cash at the moment, me and the misses are going through the process of buying our first house :-/
So I can only work with the panels I already have.
Got the companion bins welded in and that's pretty much all I have done. I probably wont have as much spare time either now so work on it will slow down. I wont sell it though!
Callum
Re: Mk2 Cooper
Post by Callum »
Not much to update as I'm still working with the bits I have already got. Last month I welded the boot board brackets
in as well as the subframe strengthener things.
This month been working on the rear valance, decided to weld the closing panels to the valance first so I can paint
and seam seal inside before it gets closed off.
