1971 Early MK3 850
LuisM
Re: 1971 Early MK3 850
Post by LuisM »
Nice work in there!
This car is similar to early Mk3 ( 850 / 1000 ) found here in Portugal... except for the front indicators and heater. Our early Mk3 had plastic heaters.
regarding the date build, our cars had toggle switches till end of 1970 , and the two boot badge combination ( Morris + 850 ) lasted till beginning of 1972... where this single badge type was introduced:
and the Assembly Plant... don't you have a letter after the body number ? like 'XA2S228609 S' ? Mk3 cars built in Portugal and Spain have 1 or 2 letters after the Body number to identify the Assembly Plant ( 'S' for Portugal 'ZA' Spain ) .
Regards
Luis
Jebo
Post by Jebo »
Hi Luis,
Good to hear from other mk3 owners!
My heater is also made from plastic, maybe it looks different?
Also no letters after the body number, there is also nothing more on the registration papers.
regards,
Jeroen
1970 - MK3 850 - viewtopic.php?f=6&t=10563
618 AOG
Post by 618 AOG »
LuisM wrote:Nice work in there!
Regards
Luis
UK market 850's only had the single speedo, not the 1000 type three instrument oval instrument cluster although from late 1978 we did have an 850 Super with the three dials.
There were a few 850/1000 cars around from the mid sebenties with the standard UK 'MINI 850' and 'MINI 1000' badges ion the boot but a single 'Austin' or 'Morris' badge fitted above - these badges were Allegro/Marina items and I've no idea why these cars had them.
I had a few early seventies 850's with the magic wand gearchange. They were okay, and the post 1974 850 with the bigger 1.5 inch SU went very well.
medwaybeat
Post by medwaybeat »
Nice project. It looks very similar to my mk3 1000. Mine has mk2 interior light, boot handle, earlier toggle switches and centre start. Regestered 1st of Jan 1971 so I'd guess 70 for manufacture.
My Belgium built MK4 (mid / late 70's) had Cibie headlights, so the rims are slightly different with 2 holes on the underside. Think there were bi directional for UK or Europe. The body plate was on the crossmember under one of the seats.
The body tag should state were it was built viewtopic.php?f=5&t=1946&start=1940
Rough dates can be picked up from glass and other items that are date stamped.
I'd guess opening rear windows, clocks, indicators and heater are for the local market.
miniminor
Post by miniminor »
That is fantastic work. I so wish I had the skill and ability (not to mention facilities) to carry out work to that standard.
Keep up the good work!
2014 Freelander 2 SD4
tedmcedd
Post by tedmcedd »
Superb body restoration!!
Look forward to seeing this progress!
NLcoopermk1
Post by NLcoopermk1 »
Jebo wrote:Can anyone help me to identify to the build date of my Mini like stated in my previous post?
Hi Jeroen, great to see your car on here! It's a real gem and in good hands! I know a guy not to far away from you has an 850 mk3 from 1970 with the same indicator lights, maybe he can help you date it. I'll send you a pm.
Groet,
Germt
About the bage, they where is MORRIS as well : 850 - 1000 - 1275 - Clubman and Cooper ! :ugeek:
JC T ONE
Post by JC T ONE »
Regards
Luis
Danish MK III Cooper S,s had those front indicators too.
Jens Christian
Jebo
Post by Jebo »
There is some more progress on the frames!!!
FRONT: Powdercoat frame and zincplate nuts and bolts and upgrade to
- Conversion 7,5 S calipers and grooved discs
- Heavy-duty adjustable tie-rods with bush kit for road/rally/race
- Rod-end adjustable, one-piece forged bottom arms (pair) with rod-ends
- Fast road lower arm bush set
- Longer track rod end
- Hub kit TIMKEN with spilt pins and seals
- Adjusta rides
- SPAX Krypton adjustable Shocks
- Hardy spicer drive shafts
REAR: Powdercoat frame and Zincplated Nuts and bolts
- Kit TIMKEN with spilt pins and seals
- Adjusta rides
- adjustable camber and castor
Jebo
Post by Jebo »
In the past two months progress has been the following!!!
Jebo
Post by Jebo »
Underseal:
And colour!!! original Flame red!!! :D :D :D
Jebo
Post by Jebo »
After painting the outside:
Jebo
Post by Jebo »
And back on his wheels after two years!!!
Mounting the rollcage:
And delivery @home to finally get my hands on it myself again :D
Sorry, maybe a bit too much pictures, but over excited about having the car home!!!
Spitz
Post by Spitz »
There can never be too many pictures!
Great work.
Curious....when did the rad shroud dissapear in production?
Jebo
Post by Jebo »
Looking at the first pics of the car there wasn't a radiator shroud... Didn't think of that before... :shock: Too bad no one mentioned it before paint ;)
But thanks for the comments!
Dr S
Post by Dr S »
Jebo wrote:And back on his wheels after two years!!!
OoooooofffFFF!
Its Redsheds sister car :-) I like that an awful lot!
Jebo
Post by Jebo »
Dr S wrote: OoooooofffFFF!
Thanks!!! I really like your car as well! Different shade of red and D1's, but def sibbelings :D
Jebo
Post by Jebo »
Silver or black GB's?
Dr S
Post by Dr S »
How about gold?
