64 Austin Cooper S 1071.
ricardo
Re: 64 Austin Cooper S 1071.
Post by ricardo »
Actually, the bracket on the car should be correct for LHD MK1 cars with twin carbs. I don't know what AKD3509/3510 states, but have seen many unmessed with LHD Coopers and Ss that have the same bracket fitted. There are a few members on this forum that can verify this. I always have seen the 14A6734 bracket on LHD 850s (single carb).
InimiaD
Post by InimiaD »
Your attention to detail is very inspiring.
I wish I was as meticulous with my pathetic efforts. ;)
skorstensfejeren
Post by skorstensfejeren »
ricardo wrote:Actually, the bracket on the car should be correct for LHD MK1 cars with twin carbs. I don't know what AKD3509/3510 states, but have seen many unmessed with LHD Coopers and Ss that have the same bracket fitted. There are a few members on this forum that can verify this. I always have seen the 14A6734 bracket on LHD 850s (single carb).
Hi Ricardo...
Thanks for the message.. I have to say I did not know that. Actually threre is 2 of thoose original brackets with my car, so guess you´re right, ;) . ( can see se you got the same brackets on your car, and I´m sure you wont do that if it aint correct.)
So until now it will stay on the car then :)
Cheers René
skorstensfejeren
InimiaD wrote:Your attention to detail is very inspiring.
Thanks InimiaD . :D ..
I´ll do the best I can, glad you like it...
skorstensfejeren
Since last time, I did little work on the inside...
Started to put on some vinyl this week.. Must say, it ain´t that easy as it look.. But so far so good...
guru_1071
Post by guru_1071 »
does your missus know you have nicked all her pegs! :lol: :lol: :lol: :lol:
skorstensfejeren
The dash rail was the most difficult one to do I think... So many corners & edges :shock:
skorstensfejeren
guru_1071 wrote:does your missus know you have nicked all her pegs! :lol: :lol: :lol: :lol:
Yes she did find out, but too late... :lol:
Red Mist
Post by Red Mist »
Looks great! What adhesive are you using? Can't get my lower dash rail to stick and have tried 2 types of glue!
Neil
skorstensfejeren
Hi Niel...
Thanks for your kind words..
The first one I tried did not work either. but after that i used the spray from Wurth... It worked very good.. No air holes at all, and you got good time to get the vinyl to fit nicely..
I found it on the web too with a picture...
http://www.slhardwoods.co.uk/Products/A ... 31877.aspx
Cheers René
Red Mist
Post by Red Mist »
Thanks René, will give it a try!
Neil
36inter
Post by 36inter »
That is excellent work, you must have a lot of patience, good luck with the rest.
Pete
scott6058
Post by scott6058 »
skorstensfejeren wrote:Hi Niel...
Cheers René
Wurth poducts are second to none.
A supplier is sometimes difficult to find in the US but it is the best. 3M would be a decent substitute but not as good.
Awesome work Rene' as always.
scott
ricardo
Post by ricardo »
Rene, you have to use more of the blue ones, they work better.
http://rsn-mk1.blogspot.pt/2012/02/fitt ... -pt-1.html
skorstensfejeren
36inter wrote:That is excellent work, you must have a lot of patience, good luck with the rest.
Pete
Thanks Pete.. For That kind of works you need a lot of patience yes...
Cheers Rene
skorstensfejeren
Cheers René
scott
Hi There Scott
I agree, 3M got some great produkts too.. Wurth is everywhere here in Denmark, so not so hard
to get here..
Hope its goes well with your project..
Cheers Rene
skorstensfejeren
ricardo wrote:Rene, you have to use more of the blue ones, they work better.
Hi Ricardo...
Really??, did not know that.. I might try this next time :lol:
skorstensfejeren
Status on my rebuild so far..
I did some work on the inside since last time...
The switch carrier in putted on, with the original cables.. Brake/ clutch, and speeder pedals are fitted, wilth the repaired brake / clutch master cylinders.
I also putted in some new sounds insulation, and the front carpets are fitted..
Soon I´ll will be working on putting the engine back, can´t wait for that job.
skorstensfejeren
A little more pictures....
scott6058
Post by scott6058 »
Very special!
My engine/trans builder is almost complete with a proper build.
The chassis is mine to do.
Thanks for the pictures.
I hope to show you mine and share soon.
You brought it a Long way. :D
Scott
