WTH??!?! Have you seen this item on ebay.
63monte
Re: WTH??!?! Have you seen this item on ebay.
Post by 63monte »
I don’t see the point in altering that particular book as it can’t be presented to DVLA as any sort of proof of existence when it is quite clearly stamped as a previously damaged total loss.
Pete
Has thanked: 15 times
Been thanked: 34 times
Post by Pete »
It’d have virtually zero value if a buyer thought that was the case, it sold for £250 so clearly somebody thinks they can do something with it. All the logbooks listed in the last few months by that seller have been altered.
IanD1965
Post by IanD1965 »
251 ENG wrote: Wed Mar 29, 2023 8:31 pm Purchasing a set of steel caps from swiftune plus the cost of good line boring will prove a shock to your wallet!
I have had this done. It cost an extra £700 to machine the thrust surfaces in apparently🙄
This was on top of the line boring and initial £300 for caps and bolts. Does that sound about right?
Polarsilver
Been thanked: 14 times
Post by Polarsilver »
These days i will be be paying a "proper" engine machine shop £95 per hour +vat .. maybe this is the going rate in UK because if the company is any good they are stacked out with work & have to pay their energy costs :roll:
Pete
Post by Pete »
The black biro’s been out again. :lol: . There must be a recently discovered well full of these.
I honestly can't imagine how these doctored log books have any value whatsoever.
Tupers
Post by Tupers »
There’s probably a lot of value to the people sellling them to would be flat pack builders….. :lol:
Exminiman
Has thanked: 21 times
Post by Exminiman »
So are they over writing them ? Looks like they might be getting their kids to do it, hardly Copperplate writing :lol:
MrNoo
Post by MrNoo »
IanD1965 wrote: Sun Apr 02, 2023 9:25 am
Think mine was 1800, that was to drill the extra two hole for centre main, we also had to move the crank up toward the deck as it had suffered a nasty on the centre main. Line bore and hone and thrust faces machined. It is not an easy job to get spot on and I wouldn't be trusting just any old engineering shop to do it, ideally one that has done them before. Also had an overbore, cam bearings and just faced the block, drill out/tap the gearbox bolt holes and tap oil gallery holes to accommodate brass tapered cap inserts, so easy to remove to clean in event of a rebuild. Obviously the latter stuff is on top of the line boring etc price
MagicWandWoody
Has thanked: 9 times
Post by MagicWandWoody »
A nomination for the Most Charmless Seller category...
https://www.ebay.co.uk/itm/334818766881 ... name=11021
mini_surfari
Post by mini_surfari »
MrNoo wrote: Tue Apr 04, 2023 6:10 pm
Who does your machining? You're not far from me.
IanD1965
Post by IanD1965 »
Who’s not far from you ?
MrNoo
Post by MrNoo »
mini_surfari wrote: Wed Apr 05, 2023 2:03 pm Who does your machining? You're not far from me.
South Cerney Engineering, but they are very expensive, had some very short inlets that I made up for twin 40's on my Arden head, angled and splayed needed facing and got stung for 360 inc vat. In their defence they did have to make a jig to hold them and also wanted a bit more off one side of a face to angle the carbs down a tad more. But saying that they do a very good job. I have used them for nearly 30 years and never had an issue (bar the price on occasion!)
imack
Post by imack »
Recently had similar block "race prep" carried out by KAD which included supplying and installing steel caps/4 bolt centre, line boring and thrust facing, offset boring, drill and tap for 11 stud an 5/16 gearbox bolts, drill and tap for screws in oil gallery bungs, semi dry deck and deck 30 thou, replace cam bearings.
£1500
Pete
Post by Pete »
Yet another fine selection of altered logbooks recently upgraded with a biro to now read Cooper from the same seller as all the others :
rolesyboy
Post by rolesyboy »
It’s such a gutter like thing to do isn’t it.
Grown men pulling naff stunts like that is just embarrassing
Duplicate
Also fraudulent … but wonder which is more so, him trying to con someone or someone using it to (try to) obtain an identity.
Has thanked: 23 times
Been thanked: 28 times
SURELY, someone with a bit of nouse or authority somewhere could have been clamping down on this. Or am I missing something.
I'd nbe thinking something along the lines of ''''pecuniary advantage by deception.....'
Pete
Post by Pete »
rolesyboy wrote: Mon Apr 10, 2023 3:43 pm It’s such a gutter like thing to do isn’t it.
Where there’s muck there’s brass and looks pretty lucrative to me!
