Page 8 of 15
Re: 1961 Austin Se7en
Posted: Fri Sep 18, 2020 8:55 pm
by AustinSe7en
Rear subframe
Posted: Fri Sep 18, 2020 8:58 pm
by AustinSe7en
Trial fitting of the front
Posted: Fri Sep 18, 2020 9:06 pm
by AustinSe7en
Manifolds on, and started fitting the master cylinders only to find the remaining pipe for the brake master isnโ€™t long enough!๐Ÿ˜ก๐Ÿ˜ก
Posted: Fri Sep 18, 2020 9:11 pm
by AustinSe7en
Flitting around all over the place!
Got to get some cupronickel pipe for the master cylinder, so thought I would offer the exhaust up.......๐Ÿ˜
Posted: Fri Sep 18, 2020 9:16 pm
by AustinSe7en
Had a centre exit Peco back in the day, so thought Iโ€™d go back to a side exit. Loving the look of it!!๐Ÿ˜
Canโ€™t wait to hear what it sounds like ๐Ÿ‘‰๐Ÿ˜ฎ๐Ÿ‘ˆ
Better get me finger out this weekend!
Posted: Fri Sep 18, 2020 9:22 pm
by AustinSe7en
Whipped the carb apart last thing today to stick in the ultrasonic cleaner overnight.
Posted: Sat Sep 19, 2020 8:17 am
by Old English White
That IS coming on nicely 8-)
Posted: Sat Sep 19, 2020 11:22 am
by MiNiKiN
AustinSe7en wrote: โ†‘Fri Sep 18, 2020 9:11 pm Flitting around all over the place!
Awesome standard of restoration. This is the bee's knees :ugeek:
No wonder, as you seem to even defy gravity ;) and BTW thanks for the reminder to go shopping before Lidl closes :D
Posted: Sat Sep 19, 2020 3:41 pm
by jay weinstein
Very nice work you're doing...You must feel very happy restoring your car
that you've had for 30 years.
Posted: Sat Sep 19, 2020 9:29 pm
by AustinSe7en
Thanks everyone for all your comments!
Thoroughly enjoying myself and canโ€™t wait to drive it.
Getting on really well, but still lots to do!
Bits all over the place here!
Posted: Sat Sep 19, 2020 9:51 pm
by jay weinstein
Upgraded to blue paper rolls?
Posted: Sat Sep 19, 2020 10:05 pm
by AustinSe7en
Brought the doors down from the back office to get them ready to go back on.
Knocked up some stainless studs and lock-tighted them in for under the wings.
Upside down to run a bit of waxoyle under the seams of the window sliding channel.
Point of interest - Cannot recommend the hinge gaskets from Miniworld Manufacturing highly enough!!
The generic ones that everyone seems to sell disintegrated after they were trial fitted and really did not fit well.
These ones are brilliant!!
Posted: Sat Sep 19, 2020 10:06 pm
by AustinSe7en
jay weinstein wrote: โ†‘Sat Sep 19, 2020 9:51 pm Upgraded to blue paper rolls?
๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚
When you gotta go, you gotta go!!
Posted: Sat Sep 19, 2020 10:20 pm
by AustinSe7en
Thatโ€™s a bit more like it!
Posted: Mon Sep 21, 2020 4:29 pm
by AustinSe7en
Carb came out quite clean really.
Might have a bit of a go at polishing the dashpot at some point, but just wanted to try and get it fired up over the weekend.
Posted: Mon Sep 21, 2020 4:46 pm
by AustinSe7en
As ever, a fair bit of fiddling around to get things fitting a bit nicer than before.
Ended up using two abutment plates!
One for the cable (once fitted) mounted to the manifold face and one mounted the other side of the carb spacer to give a proper mounting point for the throttle return spring.
Fitted the powerspark dizzy and static timed it.
Slung on the Dynamator (so I had somewhere to rest the coil!)
Egg cup of fuel in the float chamber and ..........
itโ€™s alive!!!
No hoses or coolant at the moment, so just ran it up to see how it sounds! And it sounds gooooood!!!๐Ÿ˜
Posted: Mon Sep 21, 2020 4:55 pm
by AustinSe7en
Bit of a trial fit with the coolant hoses to finish the weekend off.
Posted: Mon Sep 21, 2020 5:09 pm
by jay weinstein
Good work on getting running...looks very nice.
What are you going to use for an air filter?
Posted: Mon Sep 21, 2020 8:27 pm
by Fanfaniracing
Thigh fit with the Carb :o
What cooling hoses are these?
Posted: Mon Sep 21, 2020 10:32 pm
by AustinSe7en
jay weinstein wrote: โ†‘Mon Sep 21, 2020 5:09 pm Good work on getting running...looks very nice.
Thanks Jay, still got the offset K&N from when it was last on the road!
Hoping to clean it up and re-use it!
