Page 681 of 759
Re: WTH??!?! Have you seen this item on ebay.
Posted: Sat Mar 12, 2022 10:28 pm
by UHR850
Horrible thing.
Posted: Sat Mar 12, 2022 11:57 pm
by Hippo
https://www.barons-auctions.com/view-lo ... -s-replica
It was in their last sale and barely made 10k. Solid Mk3 from what I remember.
Posted: Sun Mar 13, 2022 9:39 am
by Old English White
Yeh, the 1098 is a lot "more potent" than a 1275. Of course it is
Probably a decent little Mk3 if it spent years in S. Africa but that doesn't make it worth almost £20,000!
Posted: Sun Mar 13, 2022 11:43 am
by Andrew1967
Looks like a left hand tank that’s been mullered to fit on the right hand side ..
But that’s only a minor issue with this car in the grand scheme of things !!!!!
Looks a good shell though but not even worth half what the seller thinks it’s worth !
Posted: Sun Mar 13, 2022 12:02 pm
by CMC
Expensive Fred Flintstone woody, surf blue resprayed fiesta yellow (or primer
https://www.ebay.nl/itm/1965-Morris-Mi ... 635-2958-0
Posted: Wed Mar 16, 2022 11:14 am
by UHR850
Posted: Wed Mar 16, 2022 11:45 am
by UHR850
Posted: Wed Mar 16, 2022 2:31 pm
by steve1071
Posted: Fri Mar 18, 2022 9:57 am
by 66Traveller
https://www.ebay.co.uk/itm/393990664076 ... SwGS1iM4tZ
Looks like someone put the boot badges on blindfolded.... Ditto the front seat covers.
Boot floor has been changed (no spare wheel bracket), boot board brackets missing at the front and painted black on the rear bulkhead. No bright trims or rivets around the door tops. And the vinyl on the upper and lower dash rails looks decidedly iffy...
Posted: Fri Mar 18, 2022 10:08 am
by 66Traveller
Sadly whoever made these didn't realise that the lettering and the checker board is white on the originals - not silver....
https://www.ebay.co.uk/itm/325106794720 ... Swh5BiM~5r
https://www.ebay.co.uk/itm/325106776164 ... Sw2yNiM~jm
Posted: Fri Mar 18, 2022 11:25 am
66Traveller wrote: ↑Fri Mar 18, 2022 9:57 am
It is the wrong 'shell isn't it? Wrong bootlid too (modified Mk3 I think?) and the shell has no air intake in the bulkhead. The reg. number looks familiar to me. It isn't the car which Barbara Alexander used to run when she took over the MCR Mk1 Cooper register is it? If so, I reckon it has had a shell change since
Posted: Fri Mar 18, 2022 11:35 am
by 66Traveller
Indeed - some things are right: hydro and later door handles. Boot lid wrong - single skinned for starters . But the absence of a hole on the bulkhead is a mystery - its not as though there has ever been one by the looks of things?
Posted: Fri Mar 18, 2022 11:39 am
by surfblue63
And the front Morris badge has a silver background
Posted: Fri Mar 18, 2022 1:33 pm
66Traveller wrote: ↑Fri Mar 18, 2022 11:35 am
It is a right strange mix and match
. The bootlid is a modified Mk3 or Heritage item (which amounts to the same thing pretty much). Look at the shape above the number plate on that car and compare that area with that of a genuine Mk1 bootlid. The top of the recess is straight across on an original lid but much more of an arc on the Mk3 type lid. It is this arc which makes aligning the Mk1 badges more difficult to achieve.
Posted: Fri Mar 18, 2022 1:49 pm
by nick@dunsdale
Bulkhead boot brackets are a different colour also been riveted on
Were riveted brackets not just on some very early ones ?
Pity decent looking shell with decent panel gaps bonnet and doors look like a decent fit
which is often not the case
Posted: Fri Mar 18, 2022 2:39 pm
by Exminiman
nick@dunsdale wrote: ↑Fri Mar 18, 2022 1:49 pm
Looks like could no bulkhead hole for Elephants trunk......maybe earlier shell ?
No seatbelt mountings ?
Looks nice shell though.......
Posted: Fri Mar 18, 2022 2:56 pm
Maybe has the higher (earlier) seatbelt mounts?
Lack of bulkhead air intake was covered earlier on.
I can't see the retaining channel for the rear quarter panel trims which again was an early car feature.
I agree, looks a good shell, but still wrong!
Can't see the header rail (above the windscreen) which would show us the sunsivor mounting area. This would be different too of course.
Posted: Fri Mar 18, 2022 5:38 pm
by 66Traveller
Yes the 'base unit' has certainly been exchanged for a pre- fresh air heater shell (so pre 63?) with high seatbelt mounts. You are right - the cant rail would be very revealing: I bet it has the early sun visors with the central chrome mount (or at least the captive nuts for them). I doubt it has any courtesy light switches either. Panel gaps (apart from the boot lid) are good.
Posted: Sat Mar 19, 2022 5:43 pm
by steve1071
Looks like an early clutch pot, also has the early seat brackets
Posted: Sat Mar 19, 2022 9:29 pm
by Exminiman
Beginning to look like a nice early car...
