Made good progress yesterday, I've nearly got the old engine ready to pull out. Since the car has had very few miles put on it since the last engine swap was performed (not counting the multiple thousands of miles it travelled via ship from NZ!), all of the bolts and fixings came free with ease.
The main challenge of the day was the heat - it must've reached around 30 degrees between 1 and 2pm, so I had to take refuge indoors and cool down for a while. Were it not for that I might've had a fighting chance at having the engine completely removed, but ultimately I'm not in a rush and I want to make sure the job is done right!
Last jobs to tackle before it can be craned out is to drain all the fluids, disconnect the heater hoses and the driveshaft rubber couplings, then unbolt the engine mounts and out she comes. Then the prep can begin for installing the new engine in its place.
I'm going to repaint it in classic MOWOG/BMC green, but retain all of the shiny DSN anodised red bits so it'll be a combination of classic Mk1 looks with a slightly modern twist. I'll also be converting it back to a standard mechanical water pump, as I don't have room to fit the electric pump without either butchering my inner wing, converting to a front mounted rad, or dry-decking the engine, none of which I really want to bother with. I will probably keep the electric fan and install a thermostatic switch so it'll be happier in traffic compared to the standard mechanical fan, especially as I've opted for a larger diameter water pump pulley which would make the mechanical fan pretty poor in standstill summer traffic.
Anyway, that'll have to happen another day, it's just too warm now so I think it's beer and BBQ time :D
![Image](https://i.imgur.com/zRYYYZe.jpg)
