1973 gtm coupe
guru_1071
Re: 1973 gtm coupe
Post by guru_1071 »
a small succes
the rear screen is in.
i used a mini seal, and it took some wrangling to get it it the hole. the screen actually went in ok, but the key strip was horrific. it you pressed too hard on the tight corners, the whole screen and seal simply popped back into the car. :?
its in now and its mega tight, there is just one little bit of the seal thats not quite right, but i think time to settle it will help it.
it took over an hour just to get the key strip in (compared to 10 min on a mini!)
oh, and the water pipes are going in slowly
tedmcedd
Re: 1973 gtm coupe
Post by tedmcedd »
Looking good! Certainly looks a lot more of a faff than a mini!!
Frogeye61
Re: 1973 gtm coupe
Post by Frogeye61 »
Makes on wonder if it will just pop into the car sometime in the future. Maybe a few rally style retainers would be ok.
guru_1071
Re: 1973 gtm coupe
Post by guru_1071 »
small progress,
the car is back on its wheels
all the pipes are in, just making a start on the loom.
i need to get my finger out, as unfortunalty ive been given notice from my rented garage as the house is getting sold
tedmcedd
Re: 1973 gtm coupe
Post by tedmcedd »
Looks great though! Top Job!
Ed
Sean1380
Re: 1973 gtm coupe
Post by Sean1380 »
I do like it Rich, kinda reminds me of a Triumph Spitfire with its front end removed looking at the bulkhead :-)
tjw89
Re: 1973 gtm coupe
Post by tjw89 »
Looking Great Rich, very good progress, shame about the rented garage.
turbochargedstu
Re: 1973 gtm coupe
Post by turbochargedstu »
i do like that rich. looks very tvr esque. where are you going to put your primark bags though???
tomkidd
Re: 1973 gtm coupe
Post by tomkidd »
Looking good Mr Guru, where did you find the wheels?
guru_1071
Re: 1973 gtm coupe
Post by guru_1071 »
tomkidd wrote:Looking good Mr Guru, where did you find the wheels?
the wheels came with the car, but i had 'put them in a safe place' and couldnt find them anywhere.
they turned up in the back of one of my mk ones that had a cover fitted on it....... :lol:
they need some new tyres, but will let me roll it around for now
the doors are all built up and fitted now, so a bit more progress
YMJ
Re: 1973 gtm coupe
Post by YMJ »
returning to the subject of the rear window - this was without doubt the most difficult job to complete for me, especially as I had to tart about with headlining material. Should have built it as a hillclimb vehicle and saved on seats, carpets, etc....
Now it's got to this stage, I've realized it's about the same year/model as mine (1988 ish)
guru_1071
Re: 1973 gtm coupe
Post by guru_1071 »
small update, but with a huge lack of photos (broken camera)
i got a repreive from getting evicted from my garage, after the guy who wanted to buy the house suddenly discovered that he was all mouth and no trousers!!
ive cracked on and can report that the loom is done and fitted, dash is in, all the electrics work, screen is in.
problems still to resolve are door seals which stop the doors shutting - arrgggg!!
oh, and the engine is built & now fitted (less the head, thats still on order)
its a 1071, 73.5mm bore, sw5 cam, 3.44:1 final drive - should be nice and smooth
me and wil got it fitted last week
8-)
Pandora
Re: 1973 gtm coupe
Post by Pandora »
you got a Baines catalogue? They are sure to have a smaller seal that'll fit.
Al
guru_1071
Re: 1973 gtm coupe
Post by guru_1071 »
Pandora wrote:you got a Baines catalogue? They are sure to have a smaller seal that'll fit.
Al
al
im a Baines regular, the trouble is that the gap isnt uniform, it goes from normal mini size to very thin
YMJ
Re: 1973 gtm coupe
Post by YMJ »
guru_1071 wrote: problems still to resolve are door seals which stop the doors shutting - arrgggg!!
talk about deja vu!!
guru_1071
Re: 1973 gtm coupe
Post by guru_1071 »
got a bit more done, i need to crack on as im getting evicted in a week or something,
the good news is the engine has oil pressure and should, all been well, running next week
the painful news, is that the exhaust just looks terrible, i think im going to have to chop it up and see if i can get it further up, it hangs down far too low.
oh, and the fricking rad leaks :(
JC T ONE
Re: 1973 gtm coupe
Post by JC T ONE »
Loking good 8-) shame about those door gaps, hope you can solve it .
guru_1071
Re: 1973 gtm coupe
Post by guru_1071 »
JC T ONE wrote:Loking good 8-) shame about those door gaps, hope you can solve it .
i cant do anything about them until the front end is fitted, as that decides the door spacing
they are a future hair tearing session, of that im sure! :lol:
Matt_Tupman
Re: 1973 gtm coupe
Post by Matt_Tupman »
From what I remember from my GTM the doors almost have to much adjustment! Everything moves and you can get lost in process. I also converted mini to Mini handles as I didn't like the Alegro ones ;)
tedmcedd
Re: 1973 gtm coupe
Post by tedmcedd »
Looks great! should be pretty quick with that engine! Shame about the exhaust.... :/
Getting closer!
