Leeds based Surf Blue 1963 Morris Mini Minor
mini_surfari
Re: Leeds based Surf Blue 1963 Morris Mini Minor
Post by mini_surfari »
Looks excellent!
morris-miner
Post by morris-miner »
Another great paint finish, looking forward to the build up photos.
miniminor
Post by miniminor »
Stunning!
The best part now building it all back up again :D
2014 Freelander 2 SD4
jay weinstein
Post by jay weinstein »
Very nice!!!!
66Traveller
Post by 66Traveller »
Those plates look superb! :)
AndyB72
Post by AndyB72 »
66Traveller wrote:Those plates look superb! :)
A team effort ;)
AndyB72
Post by AndyB72 »
We've been cracking on a bit since Christmas so I thought I'd add some updates. Its now on its wheels and is getting there bit by bit. Most of the electrics, brakes and interior are in, just some bits to finish here and there. It looks like the Speedwell dashboard is going to be a nightmare to fit without scratching it to death so that might not happen. Any to some photos... 998 brakes fitted...
Petrol tanks dipped before powdercoating, having an issue with the sender unit at the moment which has dropped a bit of a spanner in the works...
My dads garage is small so struggle to get decent photos but you get the idea of what we've been working on...
Once the petrol tank is in the boot lid can be fitted. Tick.
Dashboard needs fitting then electrics behind the speedo finish, a few more brake pipes fitting then the bonnet can go on. Tick
Then we move back on the Cox GTM. Once thats ready to send off for paint we can transport the Mini back to my garage where we have more space to fit the sunroof, doors and engine/box over. The doors are currently being built up in my garage.
java gt
Post by java gt »
The screw holding the reg lamp cover could do with a slight turn to make it 100% horizontal,my OCD is getting the better of me.I really should get out more :D :D Looks absolutely amazing btw,I wish my MKI was anywhere near as good as yours.Looking forward to more pictures of the build.
Pandora
Post by Pandora »
Looking great.
Bold move with the steering wheel. That might split opinion :lol:
Al
morris-miner
What a gem, congratulations on a stunning build.
Your cars are always so beautiful Andy!
Let me know if you need a hand fitting the dash, they are usually not as bad as they look.
AndyB72
Post by AndyB72 »
java gt that HAS to be the angle of the photo... it has to be... it must be level... IT MUST BE!!!!! Arrrrr.
Got to love a chunky steering wheel.
Mark the dash is very tight between the top rail and the screen air vents, I think the addition of the veneer and a few mm of thick lacquer isn't helping, we're going to chamfer the back of the dash to make it easier to for.
AndyB72
Post by AndyB72 »
I forgot to add this photo. The rear quarter screens were cleaned in a bath of citric acid (see thread in tech section) then I split them and swopped the outer frames over, so the chrome that was protected by the rubber is now of the outside. In the future I might get them rechromed but for the moment this is a good alternative. And yet one of the windows was so tight it needed a ratchet strap to push it back into the frame, the other one went in dead easy.
I forgot you had had it veneered. Yes, that could make all the difference. A shallow chamfer on the back should rectify the situation.
AndyB72
Post by AndyB72 »
An email from a forum member today has prompted me to add a bit of an update. The Mini is currently in my dads garage which means I can't get to it but luckily there are still plenty of jobs I can be getting on with in mine garage. The engine still needs a dummy build, which I'll do once my scabby hands are back to normal, it will probably need a lump machining off the top which might put a stop to things if the machine shop I use is closed.
I fitted-up the doors before lockdown, the sealer Mark F recommended to use under the window trim worked perfect, highly recommended...
The sun was out yesterday so I gave the seats a good clean up to see what needed doing to them, if anything. The two on the left are original to the car and have a few marks and one of them has a rip but otherwise in great condition. The two on the right are from Ebay (thanks for the heads-up Stu) and were from a low milage car. I'll use this set and just replace the diaphragms.
The email from the forum member also prompted me to have a nosey at the sunroof which has been under the bed for a few years. I think the plan with this is to wait for the sun to come out again and give it a good clean. The sunroof itself is in very good condition and should only need a good clean, the four headlining panels are another matter, they have some glue marks and the rear section has been badly screwed to the body by a previous owner. Will have to have a think about how to tackle that one.
Looking good Andy.
One the sunroof, maybe get some vinyl paint mixed up and fill the little screw holes with some flexible adhesive, then either touch in the repairs or recolour the complete headliner.
AndyB72
Post by AndyB72 »
Worth a try. Do you have a vinyl roof in your blue clubman, does the headlining fix behind the window rubbers?
That looks fantastic Andy 8-) 8-)
Nick W
Post by Nick W »
looks stunning !
Up North in Sheffield
morris-miner
That's a wonderful build, and such attention to derail is astounding.
