Casting Block Numbers
bubbacluby
Re: Casting Block Numbers
Post by bubbacluby »
mk1 wrote: Wed Jul 06, 2022 8:53 am Date codes on blocks read like this:
Assuming "S DD M Y" format of the block date code:
S = Shift. A=first, B=second
DD = one or two digit day-in-month
M=Month letter, see note below
Y=Year digit
So far, we have found photos/details of AEG312 blocks with all letters A through M except B,E,I.
I suspect letter "I" is skipped, so the resulting table would be:
A Jan
B Feb
C Mar
D Apr
E May
F June
G July
H Aug
J Sept
K Oct
L Nov
M Dec
Props to Paul Harris [TECH396] for the groundwork he did identifying sequences on other marques.
Here are some B's
251 ENG
Post by 251 ENG »
All 1071/970 blocks have it cast on front .
Early 1275 also on front then moved to backas in previous pictures
mini1973
Post by mini1973 »
Spider wrote: Wed Jul 06, 2022 7:51 am There's some here;-
https://www.minispares.com/catalogues/c ... px?1~1~234
Thank you
mini1973
Post by mini1973 »
mk1 wrote: Wed Jul 06, 2022 12:26 pm It wasn't available when John wrote the book. It was only deciphered by our members iain1967s & TECH396 in the last year or so.
8-)
iain1967s
Post by iain1967s »
Also recently posted by NZmember is this comprehensive MiniSpares page which has extensive cylinder head casting history, and includes an original BL document “Date Standard for Ferrous Castings” at the bottom which shows the same scheme was still being used into the 70s/80s.
Copy attached.
janerick3
Post by janerick3 »
When were the castings changed over to thick flanges?
I have a thin-flange block that appears to have a September 1967 casting date (engine is in the car so it is hard to read).
Sept 67 is the absolute last gasp of the thin flange block. I doubt there are any younger than that.
mini1973
Post by mini1973 »
iain1967s wrote: Thu Jul 07, 2022 12:32 am Also recently posted by NZmember is this comprehensive MiniSpares page which has extensive cylinder head casting history, and includes an original BL document “Date Standard for Ferrous Castings” at the bottom which shows the same scheme was still being used into the 70s/80s.
Copy attached.
Thanks for all the information everyone.
Anyone have a list of Gearbox casting numbers?
251 ENG
Post by 251 ENG »
Here is a late thin flange
Nevsmini
Post by Nevsmini »
Any info on the earliest thick flange block casting.
251 ENG
Post by 251 ENG »
Earlier dated one I have record of is 14/1/68 and was told it was vita race engine so it looks like thick and thin flange block had an overlap period.
Somebody did say once that Abingdon used them on 68 monte
BAD942B
Post by BAD942B »
so 30 D4A IS 30th April 64 ?
Chris A
Y=Year digit
A Jan
B Feb
C Mar
D Apr
E May
F June
G July
H Aug
J Sept
K Oct
L Nov
M Dec
BAD942B
Post by BAD942B »
this is the number below the dynamo that we fitted to the car in 1981
Chris A
BAD942B
Post by BAD942B »
and this is the spare early block with the number under the dynamo aswell
Chris A
BAD942B
Post by BAD942B »
a link to technical where the photo may be better
http://mk1-forum.net/viewtopic.php?f=3&t=36467
Chris A
Ronnie
Post by Ronnie »
Nevsmini wrote: Sun Jul 10, 2022 10:33 am Any info on the earliest thick flange block casting.
251 ENG wrote: Sun Jul 10, 2022 7:02 pm Earlier dated one I have record of is 14/1/68 and was told it was vita race engine so it looks like thick and thin flange block had an overlap period.
It looks like a thick flange on this one, Nov 66 build.
BAD942B
Post by BAD942B »
another S block, later one
Chris A
BAD942B
Post by BAD942B »
BAD942B wrote: Mon Apr 24, 2023 3:56 pm so 30 D4A IS 30th April 64 ?
what date is this code please, see photo
Chris A
hinesy1275
Post by hinesy1275 »
OK here's one from 1974?
