1275 GT thread
Re: 1275 GT thread
I agree with that.
Mark or mods., could you move some of the recent relevant 'WTH' posts to this thread please ? :)
Re: 1275 GT thread
The following will help with colours and trim for all 1969 -1980 Minis, including 1275GT. You should read it in conjunction with the paint cards to get some idea of the dates. If you look at the options there you will see when certain colours and trims were available with what other BL car models.
https://mk1-performance-conversions.co. ... _chips.htm
Re: 1275 GT thread
There's more colours
Re: 1275 GT thread
And the final batch
Re: 1275 GT thread
Thanks Stu.
Re: 1275 GT thread
Also on the main site are a couple of earlier listings of GT colours and trims
October 1969 List https://mk1-performance-conversions.co. ... Models.pdf
September 1976 https://mk1-performance-conversions.co. ... tripes.pdf
Also I do have most of the brochures for 1970s cars scanned somewhere. When I find them I will post them up.
360gts
Been thanked: 59 times
Re: 1275 GT thread
Post by 360gts »
From the E Bay thread
a) wrong servo and brackets
(b) wrong inner wings (should be no holes)
(c) wrong bonnet prop and bonnet prop position - it is on the wrong side for a 1970
(d) wrong washer bottle - shouldn't have Tudor on it
(e) wrong engine colour - should be green on a 1970 without any rocker cover sticker other than a leyland logo sticker on the front.
(f) wrong rocker cover - early 1970 1275GTs had a spout
(g) no hydro
(h) carbs are twin HS4s - an option with the "Pluspac"
(i) wrong wheels - should be 10" rostyles
(j) wrong seats - later type recliners fitted. If it was a 1970 with recliners the lever would come out of the side of the base with a cream knob
(k) wrong seat covers - it should have the early more thickly padded stitched type not the later, flatter electrically welded type
(l) wrong heater - an early 1970 has a plastic cased heater with a bright metal edge to the control panel
(m) wrong eyeball vents - they should be chrome and of the early type (with the small "toothpaste tube" type knob in the middle)
(n) wrong carpets - should be veltone
(o) rear bins should be covered in black vinyl)
(p) wrong seatbelts - should either be Kangol magnet with BL logos or early Kangol arrow static with the central floor mounted twin buckle
(q) wrong interior light - an early 1970 would have a late Mk2 type interior light mounted at the side
(r) wrong boot handle - an early 1970 generally has a MK2 type boot handle
(s) wrong rev counter - an early 1970 has a 6000 rpm red lined rev counter - the 6500 came in when the final drive ratio was changed later in production.
(t) no body number or FE number
Andrew1967 wrote: ↑Thu Sep 09, 2021 12:31 am
Noted the comment about rev counter … I thought the early ones were 6500 red line with the early diff and went to 6000 with the higher ratio diff.
I always understood that to be the case too, the 6.5k ones are certainly rarer and have the older style PCB connections etc
I think you are right - got my numbers the wrong way round! My car is in bits at the moment so hard to check!
Also, would a mid 70 have a metal or plastic air cleaner casing ?
Mine (March 1970) has a metal one - not sure when the changeover happened (or indeed if there was the usual Longbridge randomness with some later cars being fitted with earlier spec items found in the stores! My July 1967 built Mk1 850 was a classic example - it had chrome piano hinge rear side windows rather than the stainless ones....
Some time in mid to late 1970 as far as I can work out. It is rather like the bonnet hinges. 1969 built cars had bonnet hinges that bolt up into tapped threads in the bonnet framework. By the beginning of 1970 this had switched to the usual arrangement - bonnet hinges with threaded studs sticking out and flanges with oblong holes welded to the bonnet framework. Not sure why - perhaps there were problems with threads stripping, the bonnet slipping in the open position or it was just very hard to adjust! Its another of those early production quirks. My GT built early March 1970 has the conventional arrangement.
1128 all synchro close ratio box...
Yes the displacers should be silver banded.
Early cars had a dynamo with cut out box on the firewall.
Re: 1275 GT thread
Austrian Brochure from 1975
Re: 1275 GT thread
AA Road test from May 1972
Has thanked: 258 times
Been thanked: 225 times
Re: 1275 GT thread
Some useful information on the 1275GT 'sidewinder' stripes here:-
'Prune' 1275GT Stripes?
http://mk1-forum.net/viewtopic.php?p=139076#p139076
Re: 1275 GT thread
1275GT ‘Around America Economy Drive’ 1976 - David Vizard:-
http://mk1-forum.net/viewtopic.php?f=5&t=6472
Re: 1275 GT thread
1275GT Rostyle Wheels Colour:-
http://mk1-forum.net/viewtopic.php?f=5&t=20111
Re: 1275 GT thread
Popular Classics magazine - November 1995
66Traveller
Re: 1275 GT thread
Post by 66Traveller »
surfblue63 wrote: Fri Sep 10, 2021 3:21 pm Also on the main site are a couple of earlier listings of GT colours and trims
Its interesting that black was the standardised interior trim option in 1969-70 across all exterior colours (like the Mk2 Cooper / Cooper S I guess). Also interesting that Teal Blue isn't on the exterior colour published list for that year (my car was that colour from new) yet there is a Motorgraphs Longbridge production line photo from late 1969 early 1970 with an Antelope and a Teal Blue car. Presumably things had already begun to fall apart by then!
66Traveller
Re: 1275 GT thread
66Traveller
Re: 1275 GT thread
A 1969 1275GT bonnet I have showing the early bonnet hinge arrangement - revised by early 1970
66Traveller
Re: 1275 GT thread
Early stitched trim and later, flatter electrically welded
66Traveller
Re: 1275 GT thread
Later 1971 onwards chrome vents and early (small knob) 1970 chrome eyeball vents
66Traveller
Re: 1275 GT thread
1969 / early 1970 switch panel (and plastic cased heater) and late 1970 onwards (metal cased heater)
360gts
Re: 1275 GT thread
Post by 360gts »
Question.....did all GT's have the solid casting engine block?
Read somewhere that they did......
However, I saw one with the AEG312 thick flange open tappet block.
