pad4
Posts: 1090 Joined: Sun Jun 27, 2010 5:57 am
Post
by pad4 » Fri May 08, 2015 6:07 pm
this is the result of a handfull of laps round Blyton - top ball joint pin , passenger side is totally mullered , Brand new gen part fitted before Blyton - installed, gap measured, properly shimmed and torqued and greased
Any ideas chaps
Pad
Andrew1967
Posts: 7911 Joined: Thu Jun 24, 2010 6:35 pm
Been thanked: 5 times
Post
by Andrew1967 » Fri May 08, 2015 6:17 pm
- never seen one that bad Pad.
NOS genuine or brand new genuine ?
Where do 'brand new' genuine items come from .... a certain far eastern country maybe ?!
Just a thought
dklawson
Posts: 1166 Joined: Tue Feb 18, 2014 4:44 am
Been thanked: 1 time
Post
by dklawson » Fri May 08, 2015 9:07 pm
It looks like the heat treat was not carried out properly. The way it formed a ridge makes it look like the steel is dead soft.
Doug L.
Posts: 19846 Joined: Thu Jun 24, 2010 11:30 am
Has thanked: 3 times
Been thanked: 8 times
Post
by mk1 » Mon May 11, 2015 9:22 am
Looks like it totally missed out on heat treatment / hardening.
ivor badger 2
Posts: 494 Joined: Wed Dec 18, 2013 8:57 pm
Post
by ivor badger 2 » Mon May 11, 2015 11:09 am
Looking at the pin, I was wondering about the hardening process used. The tapered bit is blackened and shouldn't be. The Original BMC/ Blmc ones were induction hardened and thus only the ball end rubbing surfaces were discoloured.
pad4
Post
by pad4 » Mon May 11, 2015 11:20 am
Best send it back then - just glad it didnt snap off or that would have been expensive - the cup and everything else is fine
Pad
mister bridger
Posts: 119 Joined: Sat Dec 08, 2012 2:20 pm
Post
by mister bridger » Mon May 11, 2015 4:24 pm
I had one go exactly the same way, though probably not as quickly. Not an isolated occurence.
Daz1968
Posts: 1440 Joined: Sat Dec 27, 2014 1:41 pm
Post
by Daz1968 » Mon May 11, 2015 6:16 pm
I am still using old 1960s ones for same reason, if I see any new old stock I get them including any gaiters etc.
