How to fit a Speedwell Dash
MiniMark1
Post by MiniMark1 »
Hi all
Ive now spent hours on my Speedwell Dashboard, veneering, cutting holes for gauges & switches, too many coats of varnish to remember and finally endless polishing!
I did test fit in the car before the final stages but that was before fitting the speedo and dash vents and ashtray.
I have come to test fit prior to fitting gauges etc and I just don't seem to be able to get it under the dashboard rails!
Any tips? I really don't want to break it now!
Many thanks in advance
Mark
timmy201
Been thanked: 21 times
Re: How to fit a Speedwell Dash
Post by timmy201 »
Does anyone have a template for this style of dash? I saw one in an old mini magazine the other day and have been thinking about one since :)
swifty
Been thanked: 12 times
Post by swifty »
I sold a replica speedwell dash that I didn't use to a mate of mine a few months back . I purchased this dash from a bloke in Portugal and it was the best replica I had seen because the dash had been made with a curve in it . ... I would imagine if your dash is to stiff to bend in then this is what you need to do . You can use 3 bits of 3x2 wood with a point on them hammered into your garden lawn . ... Over a couple of days moving the centre bit in it will achieve a curve . Wrap it in plastic to protect from the rain ...... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
A lot of the repro speedwell dashes are far to think to bend. The originals were about 1/4" thick & pretty crummy really. I have seen repros up to about 8mm that I simply don't believe will fit regardless of what you do with them. Original Speedwell dashes pop into place with very little effort at all.
evonaut
Post by evonaut »
you really want to soak it then bend it in a former, or with a weight in the middle supported at each end, or pegs in the garden or however best suits, then let it dry. shame you have spent so long finishing it as the water may not penetrate, or damage the finish.....not great!
bending it dry, gradually, over a few days in a warm humid room (bathroom with shower) would be my first port of call.
raise each end and then wight the middle. gradually increase the weight or height of supports at each end and just leave it in the bath room. run the shower really hot until the room steams up then shut the door and repeat every couple of hours....
I am more familiar with joinery and structural laminating, rather than car dashes but as i said, that is how i would proceed.
not too much weight at once though. you don't want it to snap on the weak points near the dial holes.
A slightly more drastic approach if the above fails would be to use a saw with a depth gauge on it, like a festool, and cut grooves in the back at say 25mm centres which will will make it more pliable. be very careful not to cut to deep or you could end up with a faceted dash!
MiniMark1
Post by MiniMark1 »
Many thanks for the responses chaps - I will try and get it fitted over the weekend and will let you know how I get on. Cheers Mark
MiniMark1
Post by MiniMark1 »
Hi All Dashboard fitted - As Mark said its a tight fit. The only thing I did to make the fitment a little easier was to take off the chrome horizontal trim that runs the full width of the bottom dashboard rail. It was then just a case of making sure it was up behind the top rail as much as it could go and not caught up on the dash cards etc and the bottom section went in with a little persuasion!
Next job is to wire up all the gauges and switches :lol:
Thanks again for the advice
That looks excellent!
Well worth the heart ache fitting it.
MiniMark1
Post by MiniMark1 »
Thanks again for the advice Mark :)
JC T ONE
Post by JC T ONE »
That looks very nice 8-) well done.
minimans
Post by minimans »
Does it not fit up against the Speedo? I've not seen an original so don't know but it looks a little "funny" with the gap around the bezel?
rich@minispares.com
Post by rich@minispares.com »
they all have that gap
it looks great, car looks like it has some serious i.c.e fitted as well...........
'long beard boss'
MiniMark1
Post by MiniMark1 »
The gap around the speedo doesn't look too bad - I may try and fill the space up somehow. Ha - like the radio comment Rich - just need to get it converted to neg earth and FM now and the tunes will be thumping! :lol:
The gap was originally filled by a sorbo rubber gasket that stuck to the back of the dash 7 went around the speedo.
MiniMark1
Post by MiniMark1 »
Thanks Mark - any idea where to get the material to replicate?
Mark
mk1coopers
Post by mk1coopers »
Maybe a trip to the local plumbing supplies company, perhaps something like this in the right size could be made to work ?
http://www.ebay.co.uk/itm/GLOWWORM-18-3 ... 1130130457
MiniMark1
Post by MiniMark1 »
Good call Mark - off to Beaulieu Autojumble tomorrow - let me know if you are looking for anything - hopefully I will pick something up there. Cheers Mark
