Rally Suspension
Brynmor
Rally Suspension
Post by Brynmor »
Just wondering what set up (make and model) plus height people are running their rally Mini's at?
My current spax set up is pretty tired so suggestions would be welcomed..will be used for Road rallies and Historic road and stage...
pad4
Re: Rally Suspension
Post by pad4 »
First of all - what type of Rallying ? Forest - Airfield - Road
On the 8 port which is a heavy stage rally car we run Koni Shocks (but the re-valved Makinen spec ones) rally spec donughts from minispares and std trumpets - nothing fancy - totally std ride height
(front has big tie bars, neg camber bottom arms)
For airfield - i would change to std adjustable Konis, High lows and poss adj camber bottom arms with about a 1/2 std ride height
For road (bumpy roads) id go back to my stage Konis but 1/2 std ride height
Im not a believer in running the tyres right up in the wheel arches cause your fucked if you land hard and have no suspension travel.
Not so sure about ARBs - never tried them
Pad
In the shed
Post by In the shed »
Rear anti roll bar is a great thing. I use the old MS 12mm one. (might be 14mm). It makes it corner "right"
Brynmor
Post by Brynmor »
pad4 wrote:First of all - what type of Rallying ? Forest - Airfield - Road
Pad
Cheers buddy, I did pop intended surfaces in my original post lol
Astro
Post by Astro »
together with standard rubber cones, gaz preassurized dampers as Bilstein are a good solution to keep the wheels on the ground. We tried and found no better one.
pad4
Post by pad4 »
So you did Mr Brynmoor - I do need some new specs !
Pad
austinmini
Post by austinmini »
Astro wrote:together with standard rubber cones, gaz preassurized dampers as Bilstein are a good solution to keep the wheels on the ground. We tried and found no better one.
Are these Bilsteins adjustable?
