twin carb problems!
1963'S'
twin carb problems!
Post by 1963'S' »
Ok guys need your expertise
Just fitted twin 1 1/4 to a 1275 A plus.
First it wouldn't fire up, found the inlet manifold was too high allowing air in so refitted it lower.(it has a big bore inlet head but had a 1 1/4 inlet with hif 44 and ran great)
Engine fired up but won't run properly.
It revs itself really high then drops and revs again
What have we done wrong?
Any suggestions how to fix welcomed
Steve :?
Simon776
Re: twin carb problems!
Post by Simon776 »
Sounds like you still have an air leak. Is the centre branch of the exhaust manifold stopping the inlet mount properly to the head face?
1963'S'
Post by 1963'S' »
I think the exhaust manifold could well be stopping the manifold seating correctly.
I think the weld is a tad too high on the manifold and I will have to grind it a little.
Steve
mini63
Post by mini63 »
Sounds lean.....I used to have to braze half flat washers to the thick flange washers accomodate and to clamp the factory manifolds with aftermarket headers for the suggested problem you might have...
1963'S'
Post by 1963'S' »
Thanks for that, I am having another go at sorting the problem this weekend will try that also.
Steve ;)
Chalkie
Post by Chalkie »
Going the hs2 twin route on a 1275 with A big bore head cause it won't flow enough to use what spec you've got better off with a hif44 or twin hs4 or twin h4 carbs
Vegard
Post by Vegard »
Chalkie wrote:Going the hs2 twin route on a 1275 with A big bore head cause it won't flow enough to use what spec you've got better off with a hif44 or twin hs4 or twin h4 carbs
Maybe a period mark could be useful in that sentance?
Capital letters are indeed a good invention as well :lol:
rich@minispares.com
Post by rich@minispares.com »
a full stop you mean?
we are not Americans (well, most of us aren't)
oh, and its sentence
:lol: :lol: :lol: :lol: :lol: :lol:
'long beard boss'
Vegard
Post by Vegard »
I saw that, but the SS-moderator won't let me edit my post :lol:
Full stop!
Spitz
Post by Spitz »
Good thing you are not commenting on the writing styles of another member.....you may well be verbally slammed...lol
On topic..... on three separate installs of twin carbs I had to pull out the grinder....twice on the exhaust manifold, once on the intake side.
rich@minispares.com
Correcting vergs spelling has been a long standing joke between me and him
I can take the high ground as I'm fluent in norweigen...... :D
'long beard boss'
Vegard
Post by Vegard »
rich@minispares.com wrote:Correcting vergs spelling has been a long standing joke between me and him
Apart from writing "Norwegian" that is. Two errors in one word there, my fluent Englishman. :lol:
rich@minispares.com
that was a joke as well
you don't win a prize
:lol:
'long beard boss'
No, Rich is fluent in "Norweigen", he is however the ONLY native speaker :lol:
Vegard
Post by Vegard »
mk1 wrote:No, Rich is fluent in "Norweigen", he is however the ONLY native speaker :lol:
:lol:
1963'S'
Post by 1963'S' »
Found the problem, took the inlet manifold off and can see where it is hitting the exhaust manifold, also the flanges on the exhaust are thicker than the inlet.
The inlet flanges are worn down from years of tightening up the manifold.
Going to get a Maniflow inlet which should cure the problem.
Anyone used a Maniflow 1.25 steel inlet.
Steve
yes, top gear.
1963'S'
Post by 1963'S' »
I thought they would be, thanks Mark.
Good thing living where I do Maniflow is just 25 minutes away!
Steve
Yes very convenient!
But thanks to Rich, I have Minispares deliver to my door about 3 times a week at the moment :lol:
