positive or negative earth...
evonaut
Post by evonaut »
is there a definitive answer as to whether a late 69 cooper s would have been negative or positive earth? the car has always been negative earth but now is the time to change if required.
i have opted for a dynamo system instead of upgrading to alternator
thank you
rich@minispares.com
Re: positive or negative earth...
Post by rich@minispares.com »
I would have said 100% negative earth by then
'long beard boss'
360gts
Been thanked: 37 times
Post by 360gts »
69 cars still had the positive earth with the dynamo...even early 1970 MK3 models had "P" earth...
If the dynamo that is on there has Negative earth you will need to change the polarity of that dynamo...simple task. Booster cables and a fully charged battery....otherwise...just pick up a regular dynamo from any early vintage.
rich@minispares.com
I am quite often wrong........... :oops:
'long beard boss'
woodypup59
Has thanked: 6 times
Been thanked: 21 times
Post by woodypup59 »
With a dynamo you can have either polarity.
At worst, all you have to do is re-polarise it if the red light won't go out.
But an alternator is almost bound to be -ve earth, and if you have a tacho, they are polarity sensitive too.
evonaut
Post by evonaut »
the dynamo is new so should be easy to integrate within that system...... battery has not been connected as yet!
thank you all for input!
evonaut
minimans
Post by minimans »
good on you for staying with the dynamo!
dklawson
Post by dklawson »
If you are fitting a new control box with the dynamo, be sure to clean its internal contacts. Some of the modern parts available today are shipped with a protective (insulating) coating on the points.
Doug L.
ianh1968
Post by ianh1968 »
rich@minispares.com wrote:I am quite often wrong........... :oops:
Nobody's perfect...
Nifty wrote: 8-) Except me!
:lol: :lol: :lol: :lol:
Who let him in here?
