Clutch Bleeding and Gearbox
sallan850
Post by sallan850 »
hi everyone id first like to say this is going to sound a little strange but if you could help me or give me some tips that would be great.
I;ve just recently installed a new 850 engine into my super coming along well but im having some problems bleeding the clutch. i managed to get a little bit of feeling out of the peddle when i adjusted the arm but the screw is quite far out.
when i push the peddle the arm is moving just there feels like there is no pressure on the peddle.
also the gear box was very strange after i managed to get at least some movement in the clutch i tried to move the car forward when i was checking the gears i found out that in reverse gear the gear stick is still able to go upwards! feels like it has a 5th gear.
i was just wondering have i mabe put the gear lever back incorrectly and accidentally put the gear stick in when it was in neutral ?
again sounds weird but i can take a video if it helps
Thank you
woodypup59
Has thanked: 6 times
Been thanked: 21 times
Re: Clutch Bleeding and Gearbox
Post by woodypup59 »
Sounds like lost motion at the bell housing end of the clutch operating lever.
The little ball end is often missed mwhen lubeing.
Some people bend the lever but thats a bit naughty.
You may need to replace the lever and the plinger through the bell housing (which holds the release bearing).
lexie467
Post by lexie467 »
Hi,
How long has the car been standing and when did the clutch work properly ?
Tommy
sallan850
Post by sallan850 »
lexie467 wrote:Hi,
Tommy
About a year but it was always sitting still it was move around a bit from the garage to the shed so was working up until the engine was changed basically. which was a few weeks back
