Valves
Chalkie
Valves
Post by Chalkie »
Rebuilding My head but its using the old style valves with the retaining clips
is it worth upgrading to the newer style valves?
thanks
Stephen
Vegard
Re: Valves
Post by Vegard »
No, not for the sake of the valve collets/retainers themselves.
However, if you're running unleaded fuel (we all are) I've found A+ ones to be MUCH better as the are vastly harder than the old rubbish A valves. This do mean going triple collet.
Has thanked: 125 times
Been thanked: 34 times
Re: Valves
Vegard wrote: This do mean going triple collet.
I'll just add if you are going to the tripple grip collets, the Spring Retainers are different, so be sure to use the right ones.
Vegard
Re: Valves
Post by Vegard »
Chalkie
Re: Valves
Post by Chalkie »
I have a late a+ head kicking around with valves in so I can nick the exhuast ones and just buy new inlets? I know all the collects are different I was asking as this engine will be camd and double value springs aswell as it's part of the kit
Stephen
Vegard
Re: Valves
Post by Vegard »
It's the exhaust that takes the beating, so if the A+ inlets are "big enough" to make good seats, I see no reason to buy new ones.
Chalkie
Re: Valves
Post by Chalkie »
The a plus inlets are two small 27mm and my head has 29mm valves as it's a 202
Vegard
Re: Valves
Post by Vegard »
I'd buy some Minispares ones then, or find some 295s.
Chalkie
Re: Valves
Post by Chalkie »
Vegard wrote:I'd buy some Minispares ones then, or find some 295s.
Minispares have none but somerford do
Vegard
Re: Valves
Post by Vegard »
Ok.
I've used these with great success earlier:
http://minispares.com/product/Classic/E ... ssic/valve .aspx|Back to search
However, going that large on the inlet might require a bigger exhaust to balance flow.
I've used these as well previously.
http://minispares.com/product/Classic/E ... ic/exhaust valve .aspx|Back to search
The 202 certainly could use a bigger exhaust valve if perforamance is in your mind.
Chalkie
Re: Valves
Post by Chalkie »
Thanks I've saved them
Won't I need chamber work? Its been worked on around the valve seats before bigger than my other 202
ianh1968
Re: Valves
Post by ianh1968 »
Vegard wrote:http://minispares.com/product/Classic/E ... st%20valve
The valve listed above is about the largest you can fit down a
standard 998/1098 bore without block mods.
I had 1.0625" exhaust valves in one of mine and the block needed machining.
With rebore sizes, you might be lucky!
The valves were machined down 1300 type...
Chalkie
Re: Valves
Post by Chalkie »
I'll be running a +40 overbore so might be okay but I'll purchase them when I get paid
Chalkie
Re: Valves
Post by Chalkie »
Will a 202 on standard cambers
take inlet - 30.93mm and exhaust - 26.5mm valves?
