850 Thrust Washers
gs.davies
Has thanked: 49 times
Been thanked: 54 times
850 Thrust Washers
Post by gs.davies »
I'm in the process of rebuilding my engine and swapping the crank from the early small tail with a wet primary gear to a later one with a dry primary gear.
There was noticeable slack in the thrusts in the original crank and in the engine I've robbed the crank from, LOTS of slack.. Looking this morning it seems that oversize thrust washers are obsolete.
How do people get round this with 850s? Or is the case for the 1098 building?
Re: 850 Thrust Washers
You can get thin sheets of shim steel & cut out shims the shape of the thrust washer with a pair of scissors if all else fails.
http://uk.rs-online.com/web/p/product/4 ... Atlj8P8HAQ
Has thanked: 125 times
Been thanked: 34 times
Drop me a PM.
I can still get them in STD, +0.005", +0.010", 0.015" & 0.030"
Tupers
Been thanked: 7 times
Post by Tupers »
Are these the early thin type thrust washers?
When I was looking for a set last year I found a few Morris Minor specialist selling them in standard and plus sizes.
If Thornton's don't have them, they don't exist.
http://www.fwthornton.co.uk/
