MASTER CYLINDER RESTORE
minidean
Post by minidean »
Can the break and clutch master cylinders be restored. I don't think they leak so i was thinking of soda blasting them? Anyone ever done this??
UPR 65 1963 MK1 Super Deluxe
FTX 217K 1971 MK3 Cooper S
dklawson
Re: MASTER CYLINDER RESTORE
Post by dklawson »
In general the answer is yes, they can be restored.
Are you focused on a cosmetic or functional restoration? You can easily clean and re-finish the outer surfaces just like any other part. For a functional rebuild the question is what does the bore look like? If there is pitting and scoring of the bore you don't want to rebuild the master cylinder by simply fitting new seals. The pitting and scoring will just damage the new parts. For valuable master cylinders with bore damage you could have them sleeved and rebuilt by a professional.
Doug L.
nick rogers
Post by nick rogers »
For a top quality restoration use only NOS genuine ones in original Lockheed boxes. Youn know it makes sense. ;)
Jono
Post by Jono »
I would recommend Classiccar Automotive in Chelford Macclesfield - superb work, the will re plate your cans and re sleeve worn cylinders and they will come back just like new.
STG95F
Post by STG95F »
Have you got any Photos of restored cylinders by the company and what do they charge ??
Is the plating like the original dull finish ??
Thanks Ian
66S
Post by 66S »
Original plating was tin, repro's seem to be zinc.
STG95F
Post by STG95F »
I have tried everywhere to get the old tin plating redone . But all they can do is the bright zinc or yellow
Has thanked: 125 times
Been thanked: 34 times
You can get kits (even in the UK ;) ) to do your own Tin Plating;-
http://www.caswellplating.com/electropl ... -kits.html (they also have agents in the US and here in Aust)
however there are a few firms - in the UK - who do it;-
http://www.thgplating.co.uk/
http://www.ecwilliams.co.uk/tin-plating.html
Our platers can certainly do Tin Plating.
Keep in mind, many of these places tend to only deal with Industrial customers and many of those tend to put through bulk batches, so you may have a wait or they may even turn you away. The guys we use while they will do a single bolt if you like, they do have a big sign up at the counter saying they don't do Automotive Parts, I've never actually asked about that (and they do know what our bits are), but I suspect in the past, they have had guys walking in with dirty greasy, parts. I always clean and wire wheel everything, part out of respect and part because we actually get a better finish and I know they appriciate it.
I'm no electro-plater, but I think they have to copper plate steel bits first, in order to Tin Plate them.
Just be aware, while it maybe original to have them Tin Plated, this finish offers no corrosion resistance for steels, it really is for non-ferous metals.
STG95F
Post by STG95F »
Great thanks for the info
minidean
Post by minidean »
nick rogers wrote:For a top quality restoration use only NOS genuine ones in original Lockheed boxes. Youn know it makes sense. ;)
Can you text me the price Nick :roll:
nick rogers
Done.
