gearbox main bearing
As i'm rebuilding my gearbox at the moment i've got a question.
Is the coppercased mainbearing availeble anywhere as i tend to believe they stand up better to abuse by tuned engines as the later plastic cased ones?
Or does somebody know if the one 3rd down on Ebay is the one i need;
http://www.ebay.co.uk/sch/hemel72/m.htm ... 7675.l2562
Jack
Jack
- rich@minispares.com
Re: gearbox main bearing
if you are buying new, make sure you get a proper rhp one.Jack of all trades wrote:As i'm rebuilding my gearbox at the moment i've got a question.
Jack
those el-cheapo ones are deadly
- woodypup59
- Has thanked: 5 times
- Been thanked: 21 times
Mkae sure they are the correct size - I bought one with the correct part no years ago (from mini-spares) for my magic wand 'box, but it was a mm or so too large.
Not wishing to get the case line-bored, I put the old one back in to retain that authentic whine.
Its lasted OK -tho its only got to handle 28bhp of '61 850 power.
the early pre 1962 3 sync ones where different, they where 62mm od, where as the later ones where 65mm odwoodypup59 wrote:Mkae sure they are the correct size - I bought one with the correct part no years ago (from mini-spares) for my magic wand 'box, but it was a mm or so too large.
I have a NOS RHP, early type if anyone's interested. Bought as correct for a B type box... ended up not using it.
- Andrew1967
Use a nylon caged bearing, of any make, at your peril. They are rubbish.
Back in the mid eighties, the Rover garage I worked at were doing about 3 or 4 Mini/Metro gearboxes a month with broken nylon cages.
If you can find an original brass caged bearing (which do turn up occasionally) go for one of them.
- LarryLebel
the modern rhp type are fine, no issues at all, the reputation of awful plastic liners started with those weird rover bearings from the early 1980s that had a cage that stuck out of the outer of the bearing - they looked as if they had failed before they had even ever been used - the plastic case used to rub against the box and fail, which cased that 'metro whine' that all metros seamed to have.Andrew1967 wrote:Use a nylon caged bearing, of any make, at your peril. They are rubbish.
the only time I have ever seen new rhp bearings with broken plastic parts is either ones that have had a pretty serious blow up, or where people have 'stabbed' them with a screw driver when they have been fitting / removing them!
- Has thanked: 125 times
- Been thanked: 34 times
I do remember those horrid RHP Bearings, on top of what Rich has said, it seemed the oil dried out the plastic cage and made them brittle, these - if I recall - were a brown / red kinda colour. The latest ones (white coloured cage) I haven't had a problem with, seem nearly as good as the old ones with the brass cage.
- Andrew1967
Glad to hear that as I thought they were still crap.rich@minispares.com wrote:the modern rhp type are fine, no issues at all, the reputation of awful plastic liners started with those weird rover bearings from the early 1980s that had a cage that stuck out of the outer of the bearing - they looked as if they had failed before they had even ever been used - the plastic case used to rub against the box and fail, which cased that 'metro whine' that all metros seamed to have.Andrew1967 wrote:Use a nylon caged bearing, of any make, at your peril. They are rubbish.
Got a spare NOS brass tracked bearing here for that 'just in case' scenario but useful to know that later bearings are OK.
Thanks for the into Rich
