What about the 940 small valve casting which looks like the AEG163? I've seen them on a couple of 1100 engines, the ones that have the "1100" cast number in the block (unusual too). Which cars had them?
ricardo wrote:What about the 940 small valve casting which looks like the AEG163? I've seen them on a couple of 1100 engines, the ones that have the "1100" cast number in the block (unusual too). Which cars had them?
I think these would be the South African blocks, happy to be corrected on this. They were de-stroked 1275's but had a few other detailed changes too.
I don't think the SA blocks had 1100 cast into them (wheres sean when we need him!), but they where readily identifiable by having the marina type oil filter that points upwards (like the mpi).
dont forget that the SA block could be converted to a normal 1275 simply by using a 1275 crank and normal pistons, so it wasn't technically an '1100' block
Last edited by rich@minispares.com on Tue Sep 02, 2014 2:20 pm, edited 1 time in total.
