When the clutch is depressed, it disengages and re-engages correctly.
I can feel a 'roughness' through the pedal and it has started to make a graunch. This happens in any gear or neutral.
In gear it drives perfectly and I can't feel any vibration. The graunch/roughness starts as soon as the clutch starts to disengage.
I have full oil pressure etc.
The engine and gearbox were fully rebuilt about 4 years ago and have done 2.5k since.
The things that I can think of are that the clutch release bearing has broken up (it has a grey diaphragm clutch in it so it is under more load and I suspect that the low mileage doesn't do it any good!).
The flywheel could have come loose, but I suspect not as I would expect to know about this when driving it.
The thrusts could have gone, but again I suspect not as I have full oil pressure and it was rebuilt so recently.
The clutch could be breaking up, but I doubt it would happen in such a short mileage or happen over 20 miles or so.
I don't think it can be idler gears as it happens with the clutch disengaged.
.... any other ideas?
I will have to investigate at the weekend but am interested in thoughts ....
S
