I'm umming and erring about just whacking it on ebay, someone paying completely over the odds because it's a genuine downton/ST/john cooper's personal one, etc and then buying another.
My 66 has always run SUs and the bulkhead is going to need chopping around and the binnacle being carefully moved/modified. I am not a fan of autograss style dashes and it would most certainly need some work. I'm also not into running no air filter and whacking it into the back of the speedo....that strikes me as restrictive and counter productive.
So....I typed in Mini Weber whilst on ebay and noticed the 46IDA which went very high last night. I wondered, should I have a hole in the bonnet, rather than playing with my bulkhead?
Let's not worry too much about cost or inconvenience. Let's think about other factors. Vizard says "They are great and my favourite choice" but he doesn't expand and say too much about how they perform at high speeds (apart from the airflow at high speeds loses some potential power). He doesn't say whether this is solved using a filter....or anything about whether you can "interchange" proven settings between a DCOE and an IDA. Are they different in a way that DCOE man at the rolling road may struggle with them?
What's the difference between a 46 and a 48 and is that worth considering? Urrrr. That's about it.
Fire away
