MRD Racing Gearbox Mini / Ford Conversion
tomkidd
Post by tomkidd »
This looks interesting...
For sale a MRD Racing Gearbox Housing, Block Adaptor and Steel Crank Adaptor.
This Housing is to fit a Crossflow or BD Alloy Block Engine on the Mini Gearbox.
Perfect condition, No Damage, No Cracks.
This particular sump had a Cosworth Alloy 2100cc Block!
Few Mileage, Tested at 2100cc - 280BHP.
http://www.pistonheads.com/classifieds/ ... on/2205049
rich@minispares.com
Re: MRD Racing Gearbox Mini / Ford Conversion
Post by rich@minispares.com »
trouble with that is that it doesn't have the proper full crank.
those nose converters where notorious for coming loose, running out of true and generally been a pain in the arse.
I know someone who spent a fortune trying to make one work reliably in a car, before he just gave up and went back to a five porter.
'long beard boss'
I agree, those bolt on tails were far more trouble than they were worth.
In the shed
Post by In the shed »
there was a bloke on here who had a whole load of them for sale.
Then went quiet.
It's a lot of money for that....which has clearly had it's box robbed.
LDR209H
Post by LDR209H »
If you're serious about it you need one of these
Came with splined superlight flywheel,clutch plate. I will get round to it (honest guv).
Thing is, to do it justice you would use alloy block as well (£ouch !!),also need someone
with the skillbase to put it all together.
