Any info. on these used on a mini? there was a Cooper S that had them here and they looked good.
Mike
1100 front signal lights
Re: 1100 front signal lights
hi mike i used these on a mini years ago, apart from the front panel needing to be cut you will find some filler is required to blend in the outside corners to the body.
David
David
I think they are lucas 694's if it's the flat (ish) type you're thinking of.
Seen quite a few Minis over the years fitted with Morris Minor front indicator/sidelights. They're round so might be easier to fit,
I had m1000 ones on my 850 in 1976/7 think I've got some in the garage!
Yes, Riley Elfs and Worseley Hornets flat front ends in no doubted fitted,
And the Minor ones were used on Mokes.
I had a Mini fitted with MGB lights. Looked fine, if you like that sort of thing.
