Battery cable
monkeyjim
Battery cable
Post by monkeyjim »
Hi ,
Could I have recommendation of a descent supplier of battery cable and correct cable sizing please .
Using a standard Mini starter , however I cannot use the "off the shelf" length cables available as my starter button will not be in the original position . Obviously loads on ebay , not sure on the cable sizing. Will give Autosparks a call Monday , any other company suggestions would be appreciated .
David .
InimiaD
Re: Battery cable
Post by InimiaD »
If originality isn't a problem try welding cable (earth). It's far superior to standard battery cable, multi stranded, very flexible and can be cut to length as to your requirements.
I was recommended to use 16mm squared.
I'll try and dig out the invoice to confirm.
Smiffy
Re: Battery cable
Post by Smiffy »
IAIN
Re: Battery cable
Post by IAIN »
http://www.autosparks.co.uk/index.php?cPath=85_116
They will make up what ever lenght you want.
Has thanked: 125 times
Been thanked: 34 times
Re: Battery cable
InimiaD wrote:If originality isn't a problem try welding cable (earth). It's far superior to standard battery cable, multi stranded, very flexible and can be cut to length as to your requirements.
+1. This is what I use.
java gt
Re: Battery cable
Post by java gt »
I would recommend 25sq,better able to cope with voltage drop when cranking over and not much bigger to look at.
