Which CV Joints??
alexm
Which CV Joints??
Post by alexm »
Evening all,
I wondered if someone could confirm which CV joints I need...
In a nutshell i'm going to be running a 998 Cooper engine and using the original driveshafts with the maltese cross/rubber type couplings. When it comes to brakes I want to run a 7.5" Cooper S setup.
Now, how to connect all of this is my problem! The 998 Cooper would've used the smaller CV joint (shared with drum brakes I think?) but am I right in thinking I would require the other larger type of CV joint (1275/GT/1984 onwards) because of the drive flanges on the 7.5" brake setup? I wasn't sure if the female spline in the bigger CV joints would take the splined male ends of my driveshafts (maltese cross type).
Are the splines on the ends of mini drive shafts all the same so technically they'd fit into to either CV joint?
I hope that makes sense and I hope I haven't picked a driveshaft/brake combo that won't work!
Thanks,
Alex
Andrew1967
Re: Which CV Joints??
Post by Andrew1967 »
Yes, no problem, the larger CV joint will fit the drum/Cooper typed driveshafts.
I've got this set up on my 998 Cooper.
alexm
Post by alexm »
Lovely, thanks very much.
Chalkie
Post by Chalkie »
You will need to use the 8.4 Cv joints
Has thanked: 125 times
Been thanked: 34 times
Nearly all CVs will fit just about all drive shafts, the only exception being the very early 850's.
LarryLebel
Post by LarryLebel »
You'll need uprights (hubs) as well.
Lakeland997
Post by Lakeland997 »
LarryLebel wrote:You'll need uprights (hubs) as well.
To clarify, all disk braked models use the same swivel hubs so if you have 998 Cooper ones they will be fine.
